89' F150 lift kit - Ford Truck Enthusiasts Forums
89' F150 lift kit
Old 12-18-1999, 11:07 PM
nelson nelson is offline
nelson is starting off with a positive reputation.
89' F150 lift kit
I have a 1989 Ford F150 4x4 4.9L 6Cyl. 5spd. I'm looking for a 4" lift kit that people have had luck with. The Superlift kit looks good, I think they have good lifts for Fords.
Old 12-31-1999, 09:37 PM
rockcrawl rockcrawl is offline
rockcrawl is starting off with a positive reputation.
89' F150 lift kit
I just finished installing a Pro-Comp 4" lift on my '92 Flareside. Everything went well. The directions estimate 10-12 hours for installation. It took myself and a friend about 8 hours (maybe we forgot something). Removing the original pivot brackets was a pain, I wouldn't even attempt it without a cutting torch (I hate drilling rivets). I also had a hard time getting the pitman arm off. I broke the stud on the puller, and while there was still tension on it I cut through the arm with a die grinder untill it popped. The shocks that came with the kit were SHORTER than the ones I took off! But they fit. You may want to buy new trac arm bushings before you get started. Pro-Comp reccomends new Ford parts.
As for which kit to buy, make sure you know the contents of the kit. Most 'kits' are packaged by the retailer and can vary depending on where you buy them. For example, superlift offers at least 3 different ways to lift the rear of your truck; an add-a-leaf, a 2" block, or a 3" block. Some packages include the required pitman arm, some don't. Some include the shocks, some don't. Another thing to keep in mind is that most 4" lifts only lift the rear 2" to eliminate the factory 'raked' look. The kit I used had 1.75" rear blocks, and because my truck sat level before I started, it now looks low in the rear. I plan to add a leaf later.
I got the 4" pro comp kit from Summit Racing Equipment For $519. Includes shox and arm. I've seen lower prices in the magazines, but they charge $60 for shipping! Summit has it in stock and on my front porch in two days, with a $5 handling charge.
Hope this helps, and good luck!
Old 12-31-1999, 09:49 PM
89' F150 lift kit
I agree that superlift makes a good lift for the Fords (at least they sure think they do). I am by no means a geometry expert, but I do not beleive that their superunner steering kit makes any improvements over the stock steering linkage (except for looks). Actually I think it worsens it. I beleive the best thing you can do is use the stock linkage with a drop pittman arm.
One more thing, Pro comp states that installing the lift will not change the alignment by more than 1/2 degree. It's hard to beleive, but I haven't had mine aligned, and it handles great. I did have to set the toe-in (using a tape measure) and center the steering wheel.
Old 01-01-2000, 05:18 PM
89' F150 lift kit
If I go with the Superlift kit I'll get the Superrunner kit with new radius arms and new rear leaf springs. I'll leave the stock steering and add a drop pitman arm.
Thanks for the help.
Old 11-13-2001, 09:00 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
89' F150 lift kit
Skyjacker is cheaper and better. I have a 6" on my 93 f-150 4x4. I love it to death. I had a 4" superlift and i had so many problems with it. Hope i could be of some help.
-Jason-
Old 11-13-2001, 10:41 PM
85351ho 85351ho is offline
85351ho is starting off with a positive reputation.
89' F150 lift kit
superlift sucks
Old 11-15-2001, 05:32 PM
gamehunter gamehunter is offline
gamehunter is starting off with a positive reputation.
89' F150 lift kit
If superlift is so bad then would you mind sharing exactly what you have had happen to your 4"? I guess everything I have heard about superlift has been very positive. If you look at those type of kits there really isn't a whole lot of difference between any of them. Im sure 20 years ago it was completely different but I can't see how a company in high standards can suck.
Old 11-16-2001, 05:02 PM
proeliator proeliator is offline
proeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to behold
89' F150 lift kit
Old 06-03-2013, 10:05 PM
Dcivey36 Dcivey36 is offline
Dcivey36 is starting off with a positive reputation.
Lift
Whats the cheapest easiest way to lift my 89 ford 2 inches.??
Old 06-03-2013, 10:34 PM
460 FORD MAN's Avatar
460 FORD MAN 460 FORD MAN is offline
460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.
damn, a 14 year old thread?! Lmao
Old 06-03-2013, 10:56 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
With a jack
Old 06-04-2013, 04:06 AM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Brandon,
I take it you are a math major?
Paul,
That works but forklift/bobcat ftw!
Newblet,
1- start your own thread next time
2- buy leveling coils 1-2" lift. - $100-120 usually
3- expect your tires to look like this \ / and ride like crap.
Old 06-04-2013, 05:51 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
go back to skool brandon.
12 years, not 14
Old 06-04-2013, 07:39 AM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
New Guy,
As Kris said, leveling coils up front or if you really are a cheap guy, find you a set of 2wd F350 coils to get a little extra lift up front. Problem with the latter choice is finding a used set that aren't all worn out. Cheapest if to buy new. For the rear, a set of add-a-leaves or find a taller block. The block sucks, but is cheaper than the extra leaf springs. Or if you really are a cheapo, and I can't believe I'm saying this, but a body lift is really the cheapest route. Just don't use the bolts that come in the kit! Go get new grade 8 or better bolts and it will live a much longer and safer life.
With that being said, body lifts SUCK! Spend the extra money, go with spring lift and get an alignment. Just expect to be going back more often for the alignment because the TTB's don't really stay in alignment after a lift and offroad use.
Old 06-04-2013, 01:38 PM
Quote:
Originally Posted by alpha/omega View Post
Brandon,
Quote:
12 years, not 14
Look at the first post, the thread was started on 12-19-1999, 12:07 AM
and I got my g.e.d by the way :flip
Looking for lift kits Strydez 1997 - 2003 F150 2 10-15-2015 10:51 PM
2wd lift kit the same as a 4wd lift? Jeremyrj1995 1987 - 1996 F150 & Larger F-Series Trucks 17 06-12-2014 01:09 PM
Lift kits for 1985 f150 jschne52 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-11-2012 07:01 PM
lift kit White Boy 1973 - 1979 F-100 & Larger F-Series Trucks 57 03-31-2011 09:39 PM
lift kit questions ! ford_mudd_runner Offroad & 4x4 34 06-18-2005 02:29 PM
Tags
150, 1989, 6, 89, center, f150, ford, kit, leaf, leveling, lift, lifted, link, mods, springs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
