View Poll Results: Tonneau covers
Vinyl/ material type cover with snaps
12.24%
Vinyl/ material type with velcro fasteners
10.20%
Fiberglass (Gaylord type)
16.33%
Custom made, or homemade
13
26.53%
No cover at all
17
34.69%
Voters: 49. You may not vote on this poll
Tonneau covers?
Received 1,353 Likes
on
I had a vinyls cover with snaps on my '55 F-100 and it was really nice. I had it made out of white vinyl so it matched my trim. It was sharp looking, reduced the wind scoop effect in the bed, was easy to open and close - where I needed to do so - and I could completely remove it if needed.
On my 51 I am leaning toward the ******* type though. First because it is more structurally sound. Which means when it rains, I wont go out and find my cover holding 40 gallons of water and bulging down into the bed. The ******* type is more secure as well - it locks. I can go to the beach and take chairs or go to several stores and not have to worry about theft (which is more of a concern now than when I had the 55 in the mid 80s). Better UV protection and stamina for the cover itself. And it's a little less "flappy" in the wind at speed. No rusty snaps to stick over time, no popped snaps or torn snap holes.
Just a few thoughts.
J!
J!
I will most likely make a custom cover with velcro tucked up under the bottom of the rolled edges of the bedsides and probably the tailgate. I have a Truxedo on my 03 Ranger and really like it. I had contacted Kellie from Truxedo (occasionally on the forum) and tried to interest them in marketing a cover for the rolled edge type of bedside without success, My thoughts would be a rail system like on my Ranger that uses the stake bed holes to secure the rail. This allows the use of tubular stiffeners sewn into the cover preventin cover sag. I really wish Truxedo would pick up on this and market one-sewing is not in my skill set.
I scouted out different styles of tonneau covers for quite awhile before I decided to build my own. I talked to folks with each different kind at shows and such and checked out fit and aesthetics closely.
I heard mixed reviews on the snap-down and velcro type of soft cover, with the biggest problems being that the flapping can chaffe the paint on the rails and gate, the snaps were a pain and there was not much security. A couple guys had the tonneau stolen off the truck.
The ******* and other aftermarket didn't grab me. They seemed kinda tacky, and cheaply made, especially for the money. They were also reportedly difficult to install and fit right. The problem seemed to be at the hinges. The fiberglass ones looked pretty ugly on the inside when opened. I saw some custom aluminum covers that were really nice, but very pricy.
I went cheap and built my own custom tonneau, faced on both sides, vinyl-covered, with an interior light that manually switches on. Gas lifts support the weight when it is up. Overall, I am very pleased with it, although I built it a lot heavier than it needed to be. I can walk on it! I chose not to make it watertight, just route the water out bed drain holes in the front via the side support rails. I can remove it (with an extra pair of hands) very easily when I need the whole bed to haul stuff. It has worked well.
The whole album: 1956 Ford F100 4x2 - Custom Hard Tonneau
