Sick of grinding
Sick of grinding
Last week I welded in all but four of the trim/cab-light holes in my new cab before I ran out of time. I will fill in those last four this week. I counted them-- there are a total of 29 holes that I will need to grind down and then smooth out when I am done. I worked on 10 of the easiest ones to get to this weekend.
I was worried about warping the metal around each hole by grinding for too long of stretches so I had to skip around. Here are a few things I learned:
1. Get ear plugs- I can handle the noise for a while, but after many minutes, it gets old.
2. It is amazing how many different directions the sparks can go. I almost set my interior on fire when I shot a few hundred sparks into an open window.
3. Wear safety glasses or a face shield and a long sleeve shirt (See number 2. for why)
4. My hands felt pretty tired after grinding for about 45 minutes straight.
I am pretty sure I will learn many more things when I get to the last 19 or so holes left. The tough ones are the 15 of them along the cab top where the *&##ing cab lights were. I am guessing I will need to stand on the narrow front bed rail while leaning way over the cab to get to them. I am going to be very glad when this is done. It is not the most glamorous part of restoration.
I shall make a big promise. I am going to throw a big party for when I get this truck painted and back together! You are all invited to come over and marvel and/or mock my restoration skills.
Karl
Karl
I can feel the pain of grinding the filled holes down, but the cutting out the 3 feet of bed sounds really bad.
There will be no mocking from me. At least you are willing (?) and able to do your own body work on the truck. Back in the early to mid 80's I thought about learning bodywork and painting, and when I found out how much prep was involved before laying down a decent paint job, I knew I did not have the patience for that. So I chose to be more of a mechanic than a body man.
I think Karl has some stress to relieve. That is why he like the sound and power of the grinder. Then again it's probably just the way it makes him feel.
Kinda reminds me of the Tool Time Band where the guys are using different tools to play rock tunes if I remember it right. That show killed me.
Most of what i own isnt worthy of that kind of time spent on body work(thats assuming that i knew how to do body work),possibly the old International may get me to try a little crude body work,since the 59-60 IH's were kinda unique in styling. If i were to use a grinder on one of the Fords,it would likely be to get clean metal to attach a ground to....
