7.3 IDI to 7.3 Powerstroke turbo swap? - Ford Truck Enthusiasts Forums
Old 09-28-2008, 02:14 PM
chevma-67 chevma-67 is offline
chevma-67 is starting off with a positive reputation.
Has anyone done a 7.3 idi swap to a 7.3 power stroke tubo?Can this be done and what all is involed or is it a direct swap except computor and exhaust?My idi is slowly dying and starting to puff heavy blue and I have a 7.3 power stroke complete in another truck but its in a 2wd f-450 dually and I want to keep my f-350 dually 4x4.
Old 09-28-2008, 03:49 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
It can be done. It is best if you have the complete donor truck to get the parts from. Otherwise it would cost a small fortune to do it. From what I understand you have to change the dash and the tps as the powerstroke is a drive by wire and the IDI has mechanical linkage to the pump. The computer and wiring harness needs to come out of the powerstroke also. Anything can be done with enough time and money.
Old 09-28-2008, 04:50 PM
IHdieselfan IHdieselfan is offline
IHdieselfan is starting off with a positive reputation.
I'm thinking of going the other way PSD-IDI(w/a turbo). i'm tired of $300 injectors and I think the idi gets better mileage
Old 09-28-2008, 06:28 PM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is gaining momentum as a positive member of FTE.
I think it would be cool to have an Excursion with a ZF-6 and an IDI turbo.
Then I could sell my wife's Suburban.
I'm pretty sure the Excursions were all automatics and the input shaft is larger in the ZF-6 so it would be A LOT of work.
IDI acronym Bird-Dog 250 1987 - 1996 F150 & Larger F-Series Trucks 7 01-12-2016 02:04 PM
7.3 Power stroke swap in a highboy Bigred1971 1967 - 1972 F-100 & Larger F-Series Trucks 14 12-06-2015 09:06 AM
7.3 idi turbo on a 6.9 Q6.9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 03-21-2015 09:57 PM
1993 F250 idi psd swap haakj Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 05-16-2014 02:31 AM
Newbie question - Identifying 7.3IDI vs. 7.3IDI turbo vs. 7.3 Powerstroke? Bitmap Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-06-2006 08:59 PM
Tags
idi, psd, swap, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
