transmisson
transmisson
has anybody had any trouble with there trans
makes a slipping sound and makes bang sound
towards the back of the truck after i let off the
gas and get back on the gas and sometimes
it acts likes it is 4 low when i back up and
go forward and it goes way it happens when
it cold or hot but mostly when is warmed up
and it is 4wheeldrive
Follow the link in my sigantureto become one.
Sounds like u-joints in the drive shaft 4 of them.
There are 2 in the center Cardin joint which is
a pain to do but easily doable in a home garage
but they are tricky.
Don't forget to put a line on the drive shaft before
you take it apart. If you don't it could run out of
balance and cause some real problems and if you
replace 1 replace them all.
Just mt 2 cents.
I think it sounds more like universal joints rather than tranny....like Dave said up above. Crawl under truck while in park, engine off. Grab driveshaft and twist....see if there's a lot of play twisting one direction, then the other. Refer to Dave's post up the page a bit.
