Aftermarket/remanufactured vs OEM/Ford Motorcraft
My main maintenance assistant/advisor is a friend who worked as a Ford dealership mechanic for 20 years. He always recommends Ford OEM parts, which makes sense, but of course he has bias of always using factory parts at work.
So I wanted to get your opinion: Should I always spend the extra money to get an original new Ford part, or is it acceptable to substitute aftermarket/remanufactured parts?
If you like parts of questionable quality go to a parts house. It's hard to beat using Motorcraft parts, good warranty and they are the same quality as the original. When you consider how long some of the original parts have lasted the choice for a known replacement is easy. This isn't just exclusive to Ford it can be applied to almost all one's in terms of using OE parts.
Funny i was just thinking the same thing as i am in the market for a new water pump, 200K on the truck and i have no idea its condition. I have most of the truck tore apart right now due to the idler pulley snapping off after a little 4x4 in the snow.
But Motorcraft are Chinese parts granted they are built to Ford spec.
Is Ford really spending R&D into a water pump or is it outsourced to a part maker who is selling the same part under their flag?
same thing goes for other parts they are making.
A few years ago Motorcraft started offering multiple "levels" of common service parts (brake rotors are an example) in an effort to compete with the aftermarket for more market share. I think the cheaper stuff is called "service grade". While it's probably as good as the similarly priced aftermarket stuff (it's actually probably the same thing in a different box), it's certainly not the same thing as OEM Motorcraft.
So keep in mind that just because something comes in a Motorcraft box doesn't actually mean it's an OEM part. Yes some Motorcraft-branded stuff is the same OEM part, but you have to do the research. If it's as cheap as aftermarket parts, there's probably a reason.
It is my understand that, at least today, China is capable of manufacturing parts to any quality level, it's all down to the ordering company to request the appropriate spec, and QA the product to make sure the company isn't cutting corners. Certainly with tools, there is good Chinese and cheap Chinese.
This. I just put in a remanufactured solenoid pack because it was $125 and a Motorcraft part was $400. Then I saw another thread on here where someone put in an new aftermarket IAC valve, and still experienced problems, so he put in a new Motorcraft IAC valve and it fixed it. My reman'd solenoid didn't fix my problem, and I'm currently chasing shorts in the wiring harness, but now I'm second guessing if the reman'd solenoid even works correctly.
Remember the two separate collapsed crane accidents, one in New York city and the other in Florida about a decade ago where there were deaths involved. The OSHA investigation concluded both crane manufactured outsourced the steel major structural components that were manufactured in China did not have the testing to determine tensile strength and QC to ensure manufacturing to applicable ADSM standards. Why did the crane manufacture opt to use imported steel, a cost saving measure. It's understandable business is in business to make a profit, not to provide jobs. But in my opinion greed has ensued within business lines for those that want to stay profitable and in business, especially since the early 80s when global market began opening up .
If a Chinese part is speed or even part of an mfg suppl chain its going to be good.
Buying non spec parts can be an issue or not.
Some years back I had axles going on a FWD VW. Suddenly my wife decides to make a 600 miles round trip. Ergh. VW axles were like $750, Chinese that the VW Group said were **** were like $250. Trying to consolidate this, I went with the Chinese and ordered some after market axles that guaranteed rebuild and an outstanding rep in doing so (they will send you the replacement axle and a label to send the old one back so you do't get your originals). Cool.
The Chinese axles lasted a full lifetime and only hinted at breaking down at the same miles that the original axles were gone.
If its a US name brand you can Trust Rabestus and the like. Flip is if its not a US brand then no.
I would not put anything electrical in a car that was not OEM, the damage a buggy part can do is not worth it.
NAPA carries some real **** and some real good stuff and its hard to stay up with it. When in doubt go with OEM
