Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #1 (permalink)
Old 09-27-2008, 03:51 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
News Article on Scorpion
I found this and some may have already seen it from another forum. The link takes you to an article about the Scorpion but it says that it shares the same six speed automatic with the F-150? I don't think so...interesting article though.
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #2 (permalink)
Old 09-27-2008, 03:53 PM
Big J
2005 Ford F-250
Sorry, I forgot to include the link..
Article Detail
__________________
John
  #3 (permalink)
Old 09-27-2008, 09:04 PM
JIM_C's Avatar
JIM_C JIM_C is offline
JIM_C is gaining momentum as a positive member of FTE.
Notice the soot stain on the fenderwell of that truck? I guess no DPF installed on the test mule.
__________________
2003 F250 CC LB 4x4, 6.0 with auto
  #4 (permalink)
Old 09-28-2008, 04:53 PM
Big J
2005 Ford F-250
I think you're right about the DPF. Probably early test mule with an empty urea tank.
__________________
John
  #5 (permalink)
Old 09-29-2008, 02:19 AM
dc3655 dc3655 is offline
dc3655 is starting off with a positive reputation.
Now if they said that they'd improve the mileage 3mpg better than my 6L motor, then you'd really have my attention! Not that 720 ft.lb of torque doesn't get my attention, but the mileage of the 6.4L is pretty bad and so an improvement over that isn't saying a whole lot!
This is a twin-turbo, right?
  #6 (permalink)
Old 09-29-2008, 08:35 AM
origcharger origcharger is online now
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
Not sure what the deal is with Ford and their fuel mileage but many International truck/bus buyers report the 6.4 liter V8 with DPF as getting as good or better mileage than the VT365 did.
__________________
2004 E-450 6.0 139,000 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #7 (permalink)
Old 09-29-2008, 02:18 PM
a-rod's Avatar
a-rod a-rod is offline
a-rod is gaining momentum as a positive member of FTE. a-rod is gaining momentum as a positive member of FTE.
I was hoping Ford would beat the competition as far as power with this new scorpion, but the new Duramax is rumored to be 750 ft pounds. I think mpg is going to be the most important factor they need to get right.
__________________
Adam - - Collision/Refinishing Tech
2002 7.3 POWERSTROKE
100,000 miles
Straight Pipe, 6637, HPX line, pryo gauge, Foil Delete, WW, 6.0 IC + TC. Superchips Tuner.
F-350 Rear Blocks, Leveling kit
  #8 (permalink)
Old 09-29-2008, 05:20 PM
UGA33's Avatar
UGA33 UGA33 is offline
East Bound & Down!
2006 Ford F-250
UGA33 has a good reputation on FTE. UGA33 has a good reputation on FTE.
I heard it will be a single turbo
__________________
2006 F-250 Lariat FX4 CC/SB
*6L Power Stroke-SCT X3
*MBRP Exhaust-Autometer Gauges
*Coolant Filter-High Idle Mod-Leveling Kit
  #9 (permalink)
Old 09-29-2008, 07:46 PM
I agree that fuel mileage will be the most important factor for these new engines as they are all going to have huge HP and TQ numbers.
The 6.7L will be replacing a pretty good motor in the 6.4L; the only real consistent complaint I've seen on the 6.4L is the bad fuel mileage. If they can get it right and have a good running motor, then they might be able to win back over a lot of buyers that they've lost in the last few years.
I haven't seen it in a while, but I do remember one of the first articles I saw on the 6.7L Scorpion was that it would be boosted by two turbos.
  #10 (permalink)
Old 09-29-2008, 09:30 PM
UGA33's Avatar
East Bound & Down!
2006 Ford F-250
A very reliable source and i mean very reliable source said one. I trust he will be right.
__________________
  #11 (permalink)
Old 09-30-2008, 12:17 PM
pugster pugster is offline
pugster is starting off with a positive reputation.
6.4L has 2 turbos
__________________
Fords:
2008 F250SD, 4x4, 6.4L 20,000 mi.
1995 Explorer XLT, 200k/10 years
1987 F150 XLT Lariat, 5.0L 208k, 8 years
  #12 (permalink)
Old 09-30-2008, 07:33 PM
a-rod's Avatar
Hopefully its one turbo.
__________________
100,000 miles
  #13 (permalink)
Old 09-30-2008, 07:48 PM
UGA33's Avatar
East Bound & Down!
2006 Ford F-250
It will be one, and the motor is said to be an ANIMAL!
__________________
  #14 (permalink)
Old 10-03-2008, 01:36 PM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
What's wrong with compounds? I'm wanting another on my 6.0L
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
