Speaker Wire ID - Positive/Negative, and troubleshoot
I just purchased a 1994 Ford Explorer. I'm replacing the deck and four speakers (door speakers).
I need to ID the stock positive/negative speaker wires. I have white with green stripe and green with orange stripe (I just checked the right front door so the others may be different).
Also, I replaced the deck and now no speakers work at all. There is no sound. I checked and there is power going through the speaker wires from the deck, through the first harness (black harness, 8 wires, I soldered to the speaker wires from the deck). That harness connects to another harness and the wires are then wrapped (stock wiring harnesses). Can anyone tell me where that goes and then must split off to the speakers. I have power from the deck to where it plugs into the harness and no power at the speakers.
Thanks much!!!
Thanks much!!!
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Black/White
icelander_34
11-26-2020 10:39 AM
rodp14
08-03-2017 04:53 AM
BAJACRAZY32
11-11-2016 08:09 PM
jamestokelly
05-09-2016 06:02 AM
