F600 help
Old 09-26-2008, 02:34 PM
Matt99362's Avatar
Matt99362
Matt99362 is offline
F600 help
My cousin is that person in your family that has no problem dragging home stuff others don't want. this time he drug home a 1974 Ford F600 that is missing the engine and hood. I have the VIN number, but can't find a decoder to tell me what the truck came with for an engine. Anyone know if there is a decoder available for the large duty trucks like this? Anyone know what these trucks came with for engines. The transmission is in the truck and is definately a big block, but it could be anything. Any help would be great
Thanks
Matt
Old 09-26-2008, 03:06 PM
80F100man's Avatar
80F100man
80F100man is offline
Do a search, ther's a guy 'doing up' a F-600 fire truck who could maybe give you some tips.............
Old 09-26-2008, 04:05 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
I bet its a FE bolt pattern, all those trucks got 352's 361's and 391's. So whatever was in it could be repalced with a 360/390/427/428 if you so wanted to.
Old 09-26-2008, 11:31 PM
BrentNewland's Avatar
BrentNewland
BrentNewland is offline
Post the vin and NumbersDummy can tell you.
Old 09-27-2008, 06:27 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Thanks
Matt
The engine code is the 4th digit of the VIN.
1974 F600 Engines: B = 300 I-6.
FT V8 (not FE!) engines: C = 330 2V M/D / D = 330 2V H/D / E = 361 2V / F = 391 4V.
Post the VIN, I can decode the rest of it, and all the codes from the Warranty Plate, located on the left door face, below the latch.
NO: 352/360 or 390 engines were installed in anything larger than an F350!
Old 09-27-2008, 01:45 PM
Grouchy1's Avatar
Grouchy1
Grouchy1 is offline
I have one to add to the list of engine possibilities. I have a '73 f600 with a factory 359cid. It was a former uhaul truck. I love it because it's an oddball engine but it drives the parts guys nuts when you tell them what it is. I know what will fit it from the other FT engines but it's fun to mess with them a little.
Old 09-27-2008, 01:52 PM
NumberDummy
A 359 is nothing more than a 361 with low compression heads and is detuned for smog emissions.
The same thing holds true for the 389, which is a 391 with low compression heads.
According to the 1973/79 Ford Heavy Truck Parts Catalog (where those VIN engine codes I listed above came from), neither of these engines were available till 1976 on anything.
So a 359 in a U-Haul F600 from 1973, has undergone an engine swap.
What is your trucks VIN engine code?
Old 01-11-2009, 12:13 PM
first today's Avatar
first today
first today is offline
NumberDummy,
I am at my dads place. Our truck is titled as a 1975 f-600. It is a former uhaul. The 4th digit is a k.
Here is the vin #----F60KVX42501
What engine do we have?
Thanks for any help
Old 01-11-2009, 03:35 PM
NumberDummy
Originally Posted by first today
NumberDummy,
Thanks for any help
F60 = F600 2WD
K = 477 4V
V = Kentucky Truck Assembly Plant
X42501 = 1975
Old 10-05-2009, 10:32 AM
Grouchy1's Avatar
Grouchy1
Grouchy1 is offline
'73 359hd
I'll have to check the vin when I get a chance, the truck is being stored at my buddys place at the moment. You're right about the 359 being a low compression 361 but not sure about the years. In the few references I have found over the last few years about the 359hd all say it was made for the 1974 model year only for uhaul type trucks. Supposedly the low compression wasn't so much for emissions as it was to let it run on crap gas and keep your average family driver from blowing it up on the highway.
Old 10-05-2009, 10:42 AM
Matt99362's Avatar
Matt99362
Sorry guys, for some reason I never got any email reminders to check this and completely lost track of it. The truck is long gone as of now, so I no longer have the VIN. Thanks for the replies though. Sorry I didn't get back to any of you.
Old 01-06-2011, 08:34 AM
jah65's Avatar
jah65
jah65 is offline
Can you help me decode this #s 1981 ford f-150 ranger xlt vin 1ftdf15g8bra15059 trans plate # pja cj 12f18,e11p sa 010422 i know its c6 but what type, tag on rear axle wdm dc olo3, 247 9 s322b door sticker 133f151ct4k17,dso71 with foo82 to4o1 and d7te sa on block thanks.
also does anyone have pictures or something other that the vacunm diagram thats under the hood i cant figure out where the hoses go to and from
bgiesler
01-16-2017 06:18 PM
Greg36
Large Truck
09-29-2016 09:47 AM
msquared100
09-27-2010 02:49 PM
dani9678
03-15-2010 03:32 PM
Erich.Vongeist
06-24-2009 01:44 PM
Quick Reply: F600 help
