How To Center Steering Wheel (with pics) - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 09-26-2008, 03:12 AM
quietman's Avatar
quietman quietman is offline
quietman has a good reputation on FTE.quietman has a good reputation on FTE.
I have done this on two friends Super-dutys now, besides my own.
A quick search on FTE shows a lot of confusion.
So for your enjoyment...
How to center your steering wheel.
You need a 15mm box wrench and a big set of channel locks.
Park somewhere safe and get setup like this:
Looking from the drivers (left) side as in the picture you:
1. Loosen the two nuts.
2. Turn the adjustment collar.
Turn it CLOCKWISE to move the steering wheel to the LEFT.
Turn it COUNTER-CLOCKWISE to move the wheel to the RIGHT.
A half-turn of the collar moves the steering wheel about an inch.
Put a reference line on first with a sharpie.
3. Tighten the two nuts. (important!)
Drive and see how you like it, repeat as needed in finer iterations
until you are satisfied.
If the end of the bolts end up pointing up near the bottom radiator
hose, unscrew the nuts all the way off and drop the bolt in from the
top to avoid any possibility of chafing.
There you have it.
This procedure HAS NO effect on alignment, you do NOT take off the
steering wheel.
It takes longer to type it than do it...
john
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers, Auto
-zone aftermarket voltage gauge, LANDYOT Generation II Radius Rods, EBC green brake pads,
Custom 140 amp surge-proof low RPM alternator, matched Duralast 1K CCA batteries
Ford factory hood insulator, Mojave Pin-Striping
Old 09-26-2008, 08:49 AM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
quietman, first of all good job, second I noticed in your sig. you installed a Rancho steering stabilizer and I wanted to replace my OEM with a Rancho and ordered one and was not correct so I called to try to get correct one and still got wrong one, so my question is what model# Rancho steering stabilizer did you install?
Old 09-26-2008, 03:15 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Excellent post! Rep points given!
Nice when folks posts pictures as well as step by step.
Old 09-26-2008, 03:46 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Agreed.
Stewart
Old 09-26-2008, 04:56 PM
sddesigns's Avatar
sddesigns sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Great job, now I feel confident to adjust my steering wheel position just a tad back to center.
Rep given
Old 09-26-2008, 08:05 PM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE.1 is gaining momentum as a positive member of FTE.
So you cant just drive down the street and when your going straight pull the steering wheel off and put it back on straight?
On a more serious note, whats the name of that bar tahts being adjusted? Thats whats loose on my truck.
Old 09-26-2008, 08:41 PM
The DRAG LINK (short rod) is connected to the pittman arm on steering box and INNER TIE ROD is the longer rod
Old 09-27-2008, 08:18 PM
sddesigns's Avatar
Quote:
So it's the adjustment collar on the drag link that adjusts the steering wheel. I just did the adjustment and found that 2 bolts that tighten the collar weren't all that tight, just a slight turn of the wrench and they were loose. When I started to move the collar (clock wise to turn the steering wheel to the left) the whole drag link rotated in both directions, it this normal? The front end seems pretty good as far as control, no shimmys or shaking, tires that I replaced were slightly cupped on the inside (had a alignment since putting on the new tires). When I got the steering wheel almost center after 3/4 of a turn it seemded to bind as if it wasn't going any further. I just braced myself and pushed it past the point of the original position it was in when it was straight, maybe an additional 1/4 turn. It is centered now but I'm just wondering about the play in the drag link, is it normal or should I be looking to replaced the tie rod ends? They have been replaced at one time or another because they are greasable and I only have 60K miles on it.
I also tightened up the collar bolts on the inner tie rod, they were slightly tightened also (not real loose but not tight).
quietman - Thanks for you info and you were right it took less time to do it than write this post.
Old 09-28-2008, 10:02 AM
MarkMoore's Avatar
MarkMoore MarkMoore is offline
MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.
Great post - this needs to be added to the Tech Folder
Old 09-28-2008, 09:43 PM
sddesigns's Avatar
I guess I should have asked the question outside the response. Does anybody know if the movement of the tie rod is normal? It turns in both directions when I turned the collar about 1/8 of the way.
Old 09-29-2008, 09:15 AM
Cardiac69's Avatar
Cardiac69 Cardiac69 is offline
Cardiac69 has a good reputation on FTE.Cardiac69 has a good reputation on FTE.Cardiac69 has a good reputation on FTE.
Sddesigns, it should rotate. If it didn't, then you would have a heckuva time turning the steering wheel. This allows it to turn and move up and down as the suspension goes through it's travels....
Old 09-29-2008, 11:31 AM
sablejar's Avatar
sablejar sablejar is offline
sablejar is starting off with a positive reputation.
Nice write up. Seems simple enough.
Old 09-29-2008, 12:22 PM
sddesigns's Avatar
Quote:
That makes sense, thank you for clearing that up for me.
Old 09-29-2008, 12:52 PM
sddesigns's Avatar
Sorry double post
Old 09-29-2008, 07:51 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
very helpful post...
Help adjusting power assist steering box? swolh 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-15-2015 01:45 PM
72 F-250 4X4 Power Steering - Instructions with Pictures tpdaniels 1967 - 1972 F-100 & Larger F-Series Trucks 23 03-01-2015 07:16 PM
Steering Play - Is this adjustbale? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 3 11-21-2014 06:48 PM
Steering gear install 99expyTN 6.4L Power Stroke Diesel 4 10-28-2014 01:07 AM
Steering box adjustment, have we been doing it wrong? Snowseeker Excursion - King of SUVs 19 06-20-2012 10:32 PM
Tags
alignment, alignments, center, centering, crooked, duty, end, f250, ford, front, how, steering, straighten, super, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
