How To Center Steering Wheel (with pics)
Found this link...however, my 03 Exc EB doesn't appear to have the same linkage setup as the picture in the original post. Mine is a 4x2, FWIW. Mine has a knuckle coming off the steering box, which attaches to the main tie rod. From there the only two adjustment points are on the ends of each tie rod...
Any insight is appreciated on straightening the wheel.
mike
mike
I wouldn't suggest doing one like yours unless you know how to do a toe alignment. It's much too difficult to explain on here for your setup.
You would basically have to move each adjuster in equal amounts to get the toe back to center. Don't try it.
Also DO NOT EVER pull a steering wheel and try to move it if it's crooked. If it's crooked after an alignment then keep going back till it's not. Straightening the steering wheel is part of a basic alignment job but most shops don't take the time to do it right any more.
For those of you with the adjuster on your drag link after you move it to center the wheel then sight down the sides of the tires and make sure it's straight. An alignment machine looks for toe, total toe and set back. It's hard to know if you are dogtracking without a machine but you can tell pretty well just by sighting down the sides of the tires with the wheel straight. Crooked steering wheels are usually caused by idiot alignment techs but also can be caused by an axle that has shifted. I see a lot of these trucks running down the road dogtracking from improper alignments.
Thanks. Recently had an alignment, which got it closer to center, but it's still an inch or so off to the right - enough to drive me crazy.
I appreciate the feedback. This excursion is new to me, I'm a good wrench, but this is my first Ford truck, so I'm learning. Does that knuckle coming off the Pittman look bad, or need servicing? It's got a grease port, so maybe I'll push some new grease in there.
Mike
Mike
