How To Center Steering Wheel (with pics) - Page 2 - Ford Truck Enthusiasts Forums
Old 10-16-2008, 10:47 PM
fordcountry's Avatar
fordcountry fordcountry is offline
fordcountry is starting off with a positive reputation.
This is a great post and it should be posted in the TECH folder.
I just had my alignment checked and they said it was spot on, my tires are at the (60lbs cold) correct pressure but steering wheel was 1" off to the left. I performed this EASY proceedure and not it is straight as can be!!
Old 01-09-2009, 11:25 AM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE.1 is gaining momentum as a positive member of FTE.
Dealer just put a new drag link and tried roping me in for an alignment for 99 bucks. I ok'd it at first then remembered this thread. Called and canceled the alignment which was done not long ago at my buddies tire shop. Thanks for saving me $100.
Old 12-28-2009, 01:40 PM
Michael Hopton Michael Hopton is offline
Michael Hopton is starting off with a positive reputation.
Found this link...however, my 03 Exc EB doesn't appear to have the same linkage setup as the picture in the original post. Mine is a 4x2, FWIW. Mine has a knuckle coming off the steering box, which attaches to the main tie rod. From there the only two adjustment points are on the ends of each tie rod...
Any insight is appreciated on straightening the wheel.
mike
Old 12-28-2009, 01:53 PM
Here is a pic of what mine looks like underneath...
Old 12-28-2009, 03:48 PM
katiesdad7 katiesdad7 is offline
katiesdad7 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by cbradford View Post
The DRAG LINK (short rod) is connected to the pittman arm on steering box and INNER TIE ROD is the longer rod
The leg bone is connected to the foot bone and foot bone is connected to the toe bone........:-)
Old 12-29-2009, 05:48 AM
Bump...as in the pic, there doesn't appear to be an adjustment collar between the drag arm and pittman. Any help here from those in the know that have made this adjustment on a 4x2?
thanks
Old 12-29-2009, 06:03 AM
RRranch RRranch is offline
RRranch is gaining momentum as a positive member of FTE.RRranch is gaining momentum as a positive member of FTE.
I wouldn't suggest doing one like yours unless you know how to do a toe alignment. It's much too difficult to explain on here for your setup.
You would basically have to move each adjuster in equal amounts to get the toe back to center. Don't try it.
Also DO NOT EVER pull a steering wheel and try to move it if it's crooked. If it's crooked after an alignment then keep going back till it's not. Straightening the steering wheel is part of a basic alignment job but most shops don't take the time to do it right any more.
For those of you with the adjuster on your drag link after you move it to center the wheel then sight down the sides of the tires and make sure it's straight. An alignment machine looks for toe, total toe and set back. It's hard to know if you are dogtracking without a machine but you can tell pretty well just by sighting down the sides of the tires with the wheel straight. Crooked steering wheels are usually caused by idiot alignment techs but also can be caused by an axle that has shifted. I see a lot of these trucks running down the road dogtracking from improper alignments.
Old 12-29-2009, 06:52 AM
Thanks. Recently had an alignment, which got it closer to center, but it's still an inch or so off to the right - enough to drive me crazy.
I appreciate the feedback. This excursion is new to me, I'm a good wrench, but this is my first Ford truck, so I'm learning. Does that knuckle coming off the Pittman look bad, or need servicing? It's got a grease port, so maybe I'll push some new grease in there.
Mike
Old 05-30-2013, 02:42 PM
FarmingF250's Avatar
FarmingF250 FarmingF250 is offline
FarmingF250 has a good reputation on FTE.FarmingF250 has a good reputation on FTE.
I'm digging up an old post...but it was very useful!
Saved me $$$!
I used a pipe wrench since I didn't have big channel locks.
This is a VERY easy adjustment. I just went a little bit at a time until my wheel was where I wanted it to be.
Old 07-15-2013, 07:27 PM
Principle Principle is offline
Principle is starting off with a positive reputation.
For me over the top towards the front of the truck moved my steering wheel left, up and over toward the rear went right.
This was on my 2011
Old 10-29-2013, 09:07 PM
jfletcher72's Avatar
jfletcher72 jfletcher72 is offline
jfletcher72 is starting off with a positive reputation.
this was a great post and tons of help. I got my wheel centered on my own... thanks again.!!!
Old 03-30-2014, 07:38 PM
VQT VQT is offline
VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.
Remember to tighten the nuts to 41 ft-lbs
  #28
Old 08-13-2014, 04:57 PM
UnclePaddy's Avatar
UnclePaddy UnclePaddy is offline
UnclePaddy is starting off with a positive reputation.
Thank You!!!!! My steering wheel is now perfectly straight I've had 2 shops tell me i needed a new steering box and thanks to this thread it is now perfect!
  #29
Old 08-13-2014, 08:51 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
this is perfect, i've needed to do this since getting my Ex in 2010!
  #30
Old 03-23-2016, 10:04 AM
David '96PSD's Avatar
David '96PSD David '96PSD is offline
David '96PSD is starting off with a positive reputation.
is this the same procedure for a 1996 F350 CC PSD 4x4 ? apologies if this question has already been answered.(i DID read the entire thread, but only saw newer trucks mentioned)
TIA
Injector Cup R&R PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 36 12-25-2016 09:42 AM
My 05 6.0 Eddie Bauer Build/conversion. Navigator777 Excursion - King of SUVs 9 08-31-2016 05:35 PM
1994 F150/bronco steering slop regret 1987 - 1996 F150 & Larger F-Series Trucks 14 05-15-2015 07:19 PM
Steering Play - Is this adjustbale? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 3 11-21-2014 05:48 PM
Comprehensive "Steering Wander" Thread Compilation Stewart_H Excursion - King of SUVs 112 01-28-2014 05:27 PM
Tags
alignment, alignments, center, centering, crooked, duty, end, f250, ford, front, how, steering, straighten, super, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
