90 Bronco and ticked off, HELP
Rear window fight since I bought this beast. I know the motor and switch work, and the window works until I open the tailgate and after I close it, it has stopped working again. Is there a switch, sensor, or liliputin hiding that I have to activate to get consistent response. seriously why wont my window work?
Bad Idea to by-pass the switch, I don’t care how careful you think you are if someone trips the operating switch with the tailgate open or even worse not full closed you can cause a lot of damage, to the window (about $300 to replace), the operating mechanism/springs/motor, and the shell.
I don’t know if I fully believe that, my key switch is completely dead. You should still be able to use your dash switch. It might take two people (unless your dash switch sticks like mine does) but have one person hold the dash switch while one person leans or pushes against the tailgate on the drivers side near the latch, if the switch is a little weak or the strike post is worn that should trip the switch and the window will work. Also if you want a key switch I would try your local junkyard just take a ohm meter with you to test the switch.
I had a problem with my rear window not too long ago. The weatherstipping dries out and makes it hard to raise and lower the window. Silicone lubricant is the ford recommended lube for the weatherstripping. Because the window is hard to raise and lower the motor shaft (which is plastic) breaks. I got a junkyard replacement motor. I took the rear window all the way out of the tailgate to put the motor in. I broke the rear window putting it back in, so I had to get a replacement window from the junkyard. 50 for the window and 20 for the motor.
There's a lever at the bottom of the tailgate that the window activates when it's all the way down. This allows the tailgate to be opened.
So try the lube, see if that helps. Then you might think about whether the plastic part of the window motor is deteriorating.
Use an aerosol can of "dry lube" in the sides and be sure to flow it all the way down. I used white grease aeresol in the register track on the bottom of the glass. My defroster is dead however get snow every couple of years. Wire is broken in the bend in the harness and the previous owner did not cut it. Check, clean and grease the four wire tailgate connector behind the license plate. Be sure the torsoin bar, driver side, vertical part is not touching the glass. Use camera to see better.
my weatherstripping is dry rotted, and the motor plastic shaft disintegrated. Rocks are a good replacement. But it is definitely in the latching mechanism/wiring short. I do know that the defrost still works, and the dash switch for the window has been replaced, and worked for a while. Motor works when it is jumped straight to a battery.
