good engine cleaner
good engine cleaner
if you think your engine maybe getting gunked up you should try some of this>>>>http://kalecoauto.com/index.php?main...&products_id=7
I prefer seafoam. For a larger engine, throw in two cans in the tank, two in the oil, run it until you're about empty, then suck a can in through the carb til it kills the engine, let it soak for an hour, use the spray sea-foam to clean the carb/intake, start it up and take off. BG44K is also good.
For engine externals, Simple Green. Wet your engine, spray it on and let it soak for a while (rewet and respray a few times), pressure wash it off and should take off all your grime.
if you think your engine maybe getting gunked up you should try some of this>>>>Engine Scrub [ESCRB1] - $9.99 : KaleCoAuto, Hard to find automotive items!
Do they actually sell these things as gag gifts or do they just laugh at you if you try to buy something?
thats cause you didn't buy the piston return springs and install them when you put that carb on.
cutlass
02-12-2012 09:56 AM
old76er
10-22-2009 11:31 PM
