1997 explorer 4.0 intake manifold gasket replacement? - Ford Truck Enthusiasts Forums
Old 09-25-2008, 06:59 PM
Tavycal Tavycal is offline
Tavycal is starting off with a positive reputation.
If I buy the intake manifold gasket will I need other gaskets? I haave done some lite repairs in autos. I have read the manual on replacing the gasket. Can I get some tips or short cuts? TIA
Old 09-25-2008, 07:29 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Quote:
You will need the upper and lower manifold gasket set and the rocker cover gaskets. Dont skimp or cheap out, you will end up doing it twice. Take care cleaning the joint surfaces, do not scratch or gouge.
Use good hi temp RTV on the block to intake joints. New thermostat and fluids.
Use a good inch lb torque wrench,
I found taking the front wheels off and setting the rotors down on 1/2" plywood, removing the hood made the job easy, very little over reach.
My neibours had a chuckle, said the truck looked like a kneeling elephant,
Finished the job 3hrs.
Old 09-28-2008, 10:21 PM
Graygeorge Graygeorge is offline
Graygeorge is starting off with a positive reputation.
Ford parts dept. had a kit to do this at one time. 4yrs ago. It also had a new rod for something (I forgot what for) that you installed when you had the manifold off.
300 c.i. in-line 6 cyl. exhaust manifold problem. '47 Ford Ford Inline Six, 200, 250, 4.9L / 300 16 03-17-2014 12:02 PM
Intake Manifold to Spacer Gasket Rick_Fury 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-12-2011 05:02 PM
Intake manifold gaskets 77ford guy 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 06-22-2006 09:14 PM
Different Intake Gasket? gollygwagen 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-04-2005 01:23 PM
Intake manifold gasket leaking anti-freeze soverby Aerostar 9 10-13-2004 07:28 PM
Tags
40, 96, explorer, ford, gasket, intake, manifold, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
