Weight of an EFI 460 + E4OD
Old 09-25-2008, 01:41 PM
dutchlincoln79's Avatar
dutchlincoln79
dutchlincoln79 is offline
Hi there.
I'm planning on doing a engine swap.
I have a 460EFI, and a E4OD tranny attached to it, and i want to pull it out of the truck.
Can somebody tell me what this combo will weigh?
Need to know in order to get the correct engine crane..
Thanks!
Old 09-26-2008, 12:59 PM
northern 7.3's Avatar
northern 7.3
northern 7.3 is offline
Temporarily Deactivated
you're looking at 1000 lbs for the two of them or maybe a little more.
Old 09-26-2008, 01:03 PM
dutchlincoln79
ok, thanks. So i need a good crane indeed, as i suspected...
Old 09-26-2008, 01:10 PM
northern 7.3
you may not be able to get them out together. i'm pretty sure you gotta do it separately in the 80-96 bodies.
Old 09-26-2008, 01:26 PM
dutchlincoln79
it's currently located in a Lincoln MK-V
Old 09-26-2008, 03:58 PM
dutchlincoln79
It may sound stupid, but i never disassembled a tranny from an engine...
How do you do it?
Just unscrew the bolts from the engine going into the tranny?
Can i "pull" the tranny from the engine then, or do i have to watch this or that?
There's no rear-axle attached to the tranny yet.
There's a first time for everything
Old 09-26-2008, 08:59 PM
northern 7.3
no you'll likely have to undo the torque convertor bolts so you'll have to take off the inspection cover.. 4 bolts i think then get a wrench in there and undo the 4 nuts that hold the flex plate to the torque convertor, then you can back it off, make sure the convertor comes with the trans.. i have a feeling you'll have trouble if you try to leave it on the flexplate. make sure to undo the nuts holding the trans to the crossmember and you'll have to jack it up a bit for the studs to clear when you take it out, or it may be easier to remove the crossmember completely. also dont forget about the starter.
Old 09-27-2008, 12:34 AM
dutchlincoln79
okay, thank you.
Assembly is in the opposite order i assume?
Old 09-27-2008, 01:19 AM
northern 7.3
yes. make sure you get your torque convertor seated properly into the pump. you should hear 3 clicks, or clunks i guess would describe it better. it is really straight forward once you get into it, you'll see. you cant screw up the convertor bolts into the flexplate like dodge, (back to my old demo derby days) back then i could drop a C4 with a honda screw jack and a couple of wrenchs. make sure to keep the block plate in between the engine and trans. dont attempt to take out an E4OD with a screw jack!!!! lol
Old 09-27-2008, 01:47 AM
dutchlincoln79
i know, it's huge and heavy
I was thinking about getting me a motorcycle lift... you know, the small ones intended for cross bike's..
Old 09-27-2008, 03:14 AM
northern 7.3
or a stupid friend who likes to prove how strong he is. lol
Old 09-27-2008, 03:26 AM
dutchlincoln79
yeah, and coming with an empty wallet, and crashing my E4od on the street... LOL...
Don't think so
keep y'all posted
thanks.
wyattc472
17
12-17-2018 01:46 AM
TMScouts
08-11-2015 07:45 AM
jseim44
02-13-2014 09:16 AM
E4ODnut
09-05-2002 07:07 PM
Quick Reply: Weight of an EFI 460 + E4OD
