Rear Spring Change 99.5
I had a spring break on my 99.5 and picked up a set from a 2004 1 ton with overloads. I pull a gooseneck stock trailer and when I took of the ole set, the stack was 2" hign ahd the block was 4". The new set are 4" high. I did not put the block back in and was wondering if I should put in a 2" to get back to the 6" lift? The truck looks more balanced without the rear end sticking up but was wondering if this will cause any issues hauling or towing.
Any advice, suggestions?
SailCO26
03-14-2011 01:11 PM
