Intake manifold install
You use a marker to line the diz body with a fixed point so that your timing is relatively close. You might use a marker to line up the rotor with the diz body so that your rotor and gear is in time with how your engine sits if you did not first set it to TDC on #1. Personally, I like to always set the engine to TDC on #1 before pulling diz, that way, with or without a mark you know you need to set the rotor facing the #1 hole on the diz cap. If you make a mark for your diz body, I'd mark it in accordance with someting other than the intake manifold since the point here is changing the manifold.
When I built my 390 a few yrs ago, after replacing the stock mani and the stock exhaust mani's,(Edelbrock, and headers), I could actually feel the difference on the front end of the truck when driving. I figured I pulled 150lbs off of the springs. Use that cherry picker!, or another set of arms.
Alright so I finally had my truck on the road... well for about 15 min. and I decided my timing was a little off so I adjusted it and went to tighten the hold down and stripped the manifold. No big deal, I went and got a helicoil and fixed it, put the distributor back in and nothing, but a back fire every few seconds. No big deal, I'll put it at TDC and re-do it. Where is the mark and what does it look like for TDC? Sorry for the length.
FordStolz68
04-05-2015 12:37 AM
dilmachender
07-24-2014 05:36 AM
Brody Olson
32
05-01-2014 08:43 PM
