closed knuckle front end - Ford Truck Enthusiasts Forums
Old 02-23-2002, 07:52 PM
4xF250 4xF250 is offline
4xF250 is starting off with a positive reputation.
i have a closed knuckle front end on my '74 F-250. I believe it is a dana 44, don't know for sure. it has drum brakes. a friend of mine wants to trade me for his front end that is not a closed knuckle design, his has disc brakes, he wants the front end cause he has 15 in. wheels and they won't fit over his disc brake calipers. any ideas or opinions on these two types of axles, i probably am not going to make the trade as it seems like too much work cause we'd have to trade the rear axles also. of course i could always do the swap when i lift the truck since i'll already be there. any opinions on either of these two axles would be appreciated. thanks
Old 02-23-2002, 08:21 PM
canadianfordman canadianfordman is offline
canadianfordman is starting off with a positive reputation.
Where abouts are you located? I have the chance to buy a Dana 44 closed Knuckel from a 71 F250 and it comes with a Dana 60 rear end. I have been told that this front end it use less but unless you do serious 4x4ing I can't really see the problem. If I were you although you don't want to rip your friend off I would go for it. If you are close to Vancouver BC then maybe we could work something out with the ones I can get. Good Luck
Old 02-23-2002, 09:29 PM
i'm in central IL. i've heard they weren't that great but thought i'd see if soeone else had anything different to say. you know how it is if you ask the same question to 100 people you get 100 different answers, and yes we do serios four wheelin.
If It's Never Been Stuck, It's Never Been Wheelin'.
Old 02-25-2002, 06:12 AM
norulz norulz is offline
norulz is starting off with a positive reputation.
1975 F250 highboy axle swap fordtruck76_390 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-19-2008 11:57 AM
Closed Knuckle Dana 44 Disc Brake Conversion nmidthune Brakes, Steering, Suspension, Tires, & Wheels 0 04-03-2007 05:09 PM
76 highboy front end scottie2hottie 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-18-2007 07:21 PM
closed Knuckle vs. open knuckle adam king Clutch, Transmission, Differential, Axle & Transfer Case 1 12-21-2003 01:20 AM
1970 F250 Front axle 1980bigbronco 1967 - 1972 F-100 & Larger F-Series Trucks 5 06-28-2002 07:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
