Front Axle Conversion
OK, I googled it, I wiki'd it. I've drained all my 4x4 buddies knowledge. And it just seems like what's needed. I have a 2000 F150 with a 5" Superlift Suspension lift, and a 3" body lift. Over the last 9 years I've run TSL's, BFG mud terrains, Boggger, Thornbirds, and now a set of Military issues Goodyear Wrangler 37.5 tires that go on Hum Vee's. Every set scallops within 20,000 miles even with regular allignments and of cousrse rotation and balance. And I'm not easy on the old girl. Haul **** every where, spin out, Race in mud races, etc etc. The ball joints, upper and lower, idler arm,and pitman arm are wearing out so It's time for a solid axle conversion. nothing fancy, But I can't find info on Fabritech or anyone with any experience doing so. i can't be teh first. please respond with info and experience. Thanks.
Thanks UTfball68. Nice link and kudos to the guy who did a great job of step by stepping a great mod. Nice truck too. When I get home I think I'll take some pics of mine as is and start the same process with my truck. As I couldn't find any articles like the one you just linked me concerning any of teh newer 97 and up F-150. Could just be that no one is willing to cut up a newer ride. but I have more money than sense and it's time to mod my ride to allow me to run larger than 38 inch tires and get a decent upgrade rather than replace my upper and lower ball joints, pitman arm, and idler arm. Again, thanks for the info and link.
on
1 Post
Pirate4x4.Com Bulletin Board - Powered by vBulletin
Join up and talk to farmboyfab. Hes done this and sells kits. Not a 4 link like the others but he actually wheels his stuff. If you search there in the ford forum this issue has all be talked about before.
please post your build progress! with pics!
if i may suggest though.... it seems you are very willing to do this and have the resources, you just need some guidance. might i suggest building a coiled D60 front with 4-link? i dont think coilovers would do you much good unless you were gonna rockcrawl and simple coils will keep your cost down significantly! i think you could spend less money than a kit and get a better performing truck, not to mention you will get a 1 ton front under it which you will need (sounds like you are rough on trucks and if you plan to move up to 38's a D44 front wont do you much good for long!)
just my few cents worth!
-cutts-
-cutts-
on
1 Post
I agree with all points peeps. Good info and exactly what I'm looking for. I'm going to steup up to the 60 front. No use doing it half ____ed. I'm a design engineer by trade and have been designing and 3D modeling for over a decade. I've decided to do the layout and design myself as I can not find good info or kits. I've got several good fab shops locally (I live near the Mobile Alabama area) and can see saving tons of money buying fab'd parts here.
not disagreeing with you, but i do think a well balanced system can help you as much as a good set of tires. i am certainly not condoning the use of $1000 coil overs and $1000 worth of heim joints for a mud truck!
just my opinion
-cutts-
Although the long travel is nice, its the complexity of IFS I'm trying to steer away from, pun intended. I've had good success with Superlifts new knuckles but I want the added durability of a solid axle. As a mechanical engineer I'm fond of the KISS principle. But I doubt I beef it up as good as Fishman was suggesting. a D60 would be nice but is probably over kill for my ride. Although my truck is far from a Mall Crawler I don't race it or beat box it near as much as I use to. a D44 should do nice and give me more strength than my current system. I was suppose to take current pics this weekend but got entirely too drunk this weekend. I'll try and get those posted in the next couple of days.
Not to ruin your parade, but why not get a different truck? I mean, sell this one and get a bunch of money out of it, and buy one that already has a solid axle.
Me personally, I think a 90s F350 would be a great truck to start with. Diesel or 460FI, 5 spd, D60 front, sterling rear.
Just a thought.
Just a thought.
