Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
  #1 (permalink)
Old 09-23-2008, 09:39 PM
Krazy_Knuck Krazy_Knuck is offline
Garage is empty, add now
Krazy_Knuck is starting off with a positive reputation.
Power Steering Fluid Change
Hi,
I have 04, Scab 4.6 V8, 4x4 and wanted to know what's the best way to change the power steering fluid.
Do you remove from PS reservoir and add new fluid a few times or can I remove one of the lines to drain?
Thanks!
Krazy
  #2 (permalink)
Old 09-23-2008, 10:06 PM
azfordf100man's Avatar
azfordf100man azfordf100man is offline
azfordf100man is starting off with a positive reputation.
You could do it that way, but I just take a turkey baster remove fluid, run the car and repeat. Not as effective maybe but very easy.
__________________
1977 F250 Highboy: Ol' Yellar, bored 429, cam, intake, Dual Spintech 9000 Exhaust
  #3 (permalink)
Old 09-24-2008, 12:25 PM
osbornk osbornk is offline
osbornk is gaining momentum as a positive member of FTE.osbornk is gaining momentum as a positive member of FTE.
Why would anyone want to change the fluid? When you do it, don't forget to change the air in your tires.
__________________
2004 XLT Regular Cab, Short Bed, 4X4 with 5.4 and 3.73.
  #4 (permalink)
Old 09-24-2008, 12:32 PM
tseekins's Avatar
tseekins tseekins is offline
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
OMG I'm dying here! LMAO! I've never heard of anyone changing PS fluid, but if you feel compelled to do so, you can buy a kit from walmart that will extract engine oil from a lawn mower, it'll be quite effective, I have one.
Tim
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #5 (permalink)
Old 09-24-2008, 04:30 PM
I live in Canada where we get very cold winters along with big fluxuations in humidity which can lead to moisture in PS unit causing premature failure. But hey with a smart a-s-s answer like that I doubt you'd have a clue where Canada is on a Map anyway!...LOL
Krazy
  #6 (permalink)
Old 09-24-2008, 04:45 PM
Hmmm, I don't think changing the PS Fluid is all that crazy? It's only a few bucks anyways.
__________________
  #7 (permalink)
Old 09-24-2008, 04:49 PM
basstardo's Avatar
basstardo basstardo is offline
basstardo is starting off with a positive reputation.
It can get pretty nasty actually, and it's recommended on the Super Duty models, especially if they're lifted because of the added strain on the power steering pump. Like all petroleum based fluids, they wear out and collect contaminants. You don't need to change it as often as you oil, but I did mine about every 75-100K when the fluid started getting really dark. The easiest thing to do is get length of tubing that will connect to the sending line on your PS pump. Direct that tube into a bucket and have someone turn the wheels side to side with the engine running. As the fluid in the reservior is drained, add new fluid. Takes about 20-30 minutes on a Super Duty, not sure about the F-150's.
__________________
Terry
2003 F-250, 6.0L PSD, Crew Cab 4x4, blue spring upgrade, Magnefine PS filter
  #8 (permalink)
Old 03-21-2011, 07:13 PM
chevyman1988 chevyman1988 is offline
chevyman1988 is starting off with a positive reputation.
Kidding, right? Right.
Ok I hope youre kidding about changing the fluid in your Power Steering. For one it doesnt have a filter so the pump pushing little chunks of deposits and sludge through the lines, putting stress on the pump and ultimately could and probably will lead to needing the pump replaced. $75-$150 if you can do it yourself, $200-$300+ if not. Luckily it happened to my Subaru and I could do it myself. Paid $75 online. If youre talking about changing from winter air to summer air...that one cracks me up every time. And 80% of the customers either get confused or believe me when I tell them it's a service, only $24.99...
  #9 (permalink)
Old 03-22-2011, 05:33 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
You can extract fluid from the resevoir with any hand suction device. I use a Lincoln oil suction gun personally. I remove some of the fluid every other oil change and top off with new Mercon V. It can't hurt to do PM on anything mechanical.
  #10 (permalink)
Old 03-22-2011, 06:17 PM
Quote:
Good idea Djack. Have you always done this for your vehicles and has your pump ever gone out on you? Since most manufacturers dont have a set interval on when to replace your PS fluid; where I work, we follow the motorist assurance program guidelines which is to do a complete flush every 50k miles, which is $79.99. I get a 50% discount, but before my pump went on my Subaru at 135k miles, I never did any type of PM except the very basic. Luckily I was able to install it myself, but still almost a $150 part.
  #11 (permalink)
Old 03-22-2011, 08:47 PM
tseekins's Avatar
2011 Ford F-150
I've only replaced one PS pump in my entire life and never flushed a single system. While I agree that good routine maintenance is never a bad thing, I'm still not going to change my PS fluid.
__________________
Tim
2010 Ford Focus
FTE Guidelines
  #12 (permalink)
Old 03-22-2011, 11:10 PM
I've only replaced 1 P/S pump of my personal vehicles but have replaced a few of them on other friends. Also, a couple of the old type power steering sectors on F150 -350's. One common problem was excessive amount of metal in the fluid. If a vehicle is in this condition it may not be advantageous to change the fluid until repairs are needed. Like a neglected automatic transmission new fluid may cause more leaks or failure. A judgement call or personal prefference. P/M from the start of ownership is best IMHO.
  #13 (permalink)
Old 03-24-2011, 12:59 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
These system are easy to flush, take the hose off the cooler from under the truck and place it in a bucket or container. Then have someone else start the truck and run a gallon of fluid through the system and have the other person go full lock left to right during the process.
  #14 (permalink)
Old 03-28-2011, 07:00 PM
baitmaster baitmaster is offline
2005 Ford F-150
baitmaster is starting off with a positive reputation.
A few yrs back, I bought a ps kit from a shyster in Iowa. (Didnt know he was til I got the box full of parts). Was for my '72 F100. Put it all together, and the pump whined like heck. Sounded like it had sand in it. So called him,and he reimbursed cost of rebuilt pump. Changed fluid again. Then a month later, steering box started leaking. Called him again, and couldnt get him to call back after several tries. Went to store, bought another one, put it on, and changed fluid again. Looked to me that he went to the junkyard, found what I needed, and sprayed a nice coat of black paint on everything. The wrapping paper in the box was partially stuck to the sticky paint. One of these days, when I get back to that neck of the woods, I'm going to look him up.
  #15 (permalink)
Old 03-29-2011, 08:36 PM
Quote:
I've never changed the fluid or had a pump go bad but I only drive 35-45K per year and I didn't start driving until 1962.
Of the 15 new vehicles I have had, I don't recall one that mentioned changing the PS fluid.
__________________
Tags
1977, 1996, 2007, add, chanage, change, changing, f150, f250, fluid, ford, power, ranger, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
