Propane Tank as an Air Tank?
Air Tank Conversion Kit
this was made for r12 freon tanks, but it should be adaptable to a propane tank
Don't do it, they aren't coated on the inside to resist rust. The higher than atmosphere pressure will accelerate the rusting. You need a tank valve(unlawful to put anything thru the left handed Propane valve other than Propane or leak testing nitrogen), pressure gauge, relief valve and hose for the tank. By the time you bought all those, and the fittings you could have bought a portable air tank. Get caught transporting it and you could be in for a nasty fine. Bump a pressurized tank and you could be wearing part of the tank. The same holds double for freon tanks, as they are thinner.
Please, he could get all the parts he needed to convert it for 10-15 dollars if he looked around. I'd assume he has a water separator on his compressor anyways. Even if you were that paranoid about rust, you could just dump a bit metal paint into the tank and swish it around to evenly coat the insides and let it sit for a day or two to dry. I know many people who run air tanks, they fill them with humid air, leave them outside, never drain the water out, etc., and I have not seen one fail yet.
I have an older steel 100lb tank that we use at the farm. I cut the valve off at the neck and then drilled and tapped it for a pipe tee. Added a gauge, pop-off, and quick-coupler to it.
Check E-bay for the propane / air tank conversion valve. It is left-handed thread and has a port for gauge and pop-off along with the 3/8npt for a standard coupler.
Madathlon
57
04-19-2005 05:41 PM
