brake and blinker lights don't work - Ford Truck Enthusiasts Forums
Old 09-23-2008, 07:43 PM
boggerted boggerted is offline
boggerted is starting off with a positive reputation.
I had to repair some of the wires going to the taillights after the plug that attaches it to the main harness because the wires got melted while torching the old bed off. I tried to fix the wiring, and got the passenger side taillights all working perfectly. On the drivers side, though, only the reverse light comes on, and when you turn on the headlights the dual filament bulb turns on. It will not blink for the turn signal or light up when the brake is applied. What wires should I look at? Thanks.
Old 09-23-2008, 09:21 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Here's a diagram with the wire colors.
http://www.autozone.com/images/cds/g...3d800ce991.gif
Old 09-23-2008, 09:27 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
I'm having a similar problem with my truck.My turn signals won't work on either side,my reverse lights don't work,and my brake lights don't work.They light up when I turn the lights on,but when the brake is applied,they do nothing.Now it might be the thing that attaches to the brake pedal,but the previous owner of my truck cut wires for trailer brakes.I've reattached most of them,but there's still a couple that aren't connected...
No taillights Cdjbmb2007 1999 to 2016 Super Duty 2 03-11-2015 06:55 AM
Aftermarket turn signal problem. Please help! jhaas63 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 01-03-2014 06:20 PM
7-pole wiring on tent trailer????? loudfords Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 4 06-19-2008 03:01 PM
brake light and turn signal problems abe 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 11-20-2005 04:36 PM
rear lighting problem slick78 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-17-2002 07:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
