Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-23-2008, 02:30 PM
Beanscoot Beanscoot is offline
Beanscoot is starting off with a positive reputation.
Reusing Torque to yield bolts
I will be replacing a head gasket on another Escort 1.9L engine, and although it's not a truck perhaps I can get some advice about it here.
I did one of these cars about a year ago, and replaced the TTY head bolts and had the head reconditioned at a shop. I would like to not bother with new head bolts this time, as I will have two complete used sets so I would have spares if any failed during torquing.
The new ones will almost certainly be Chinese anyway, so of dubious quality. My other thought is to just pretend that the bolts are conventional style, and find an appropriate torque value to tighten them to. The head gasket presumably doesn't know how it's being clamped.
I have read also that it's permissible to use TTY bolts twice.
Any thoughts?
  #2 (permalink)
Old 09-24-2008, 09:33 PM
TigerDan's Avatar
TigerDan TigerDan is online now
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
I've never heard of using them more than once. They stretch when you torque them, and stay stretched so you dont get the proper torque when you try to reuse them. I wouldn't chance it...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 09-25-2008, 12:10 AM
Well I agree that they stretch when you tighten them. Then the next time they stretch a little more... it turns out that on some engines the TTY bolts may be reused a couple times, and on others they may not. In reading up on this I found a cryptic reference to the importance of "cycling" the fasteners as a necessary high performance preparation. I didn't find a definition of this practice, but it sounds like tightening them and loosening them a few times... huh? Isn't that what's verboten?
On the Engine Builder's website I gleaned this titbit:
"A well-respected OE engineer specializing in engines tells me that critical fasteners have about six rundowns in their useful life. They use four of those at the OE manufacturing operations, leaving rebuilders just two. One rundown for checking sizes puts us on the last rundown during final assembly. My thinking is: why take the chance? Replace the fasteners! The relative cost compared to the total engine job is small and the peace of mind is high."
So this engineer says that they can be used six times. I don't understand how four of those are used up on the assembly line, nor the "one rundown for checking sizes", but "leaving just two" for the rebuilders kind of says that it's okay to use them.
This seems like a really murky topic and I suppose I should do a bit of testing myself to figure it out. Last year when I did one of these engines I did get the Felpro gasket kit with headbolts, and when carefully retorquing and final turning of the head bolts found that some were really easy to turn, and some difficult. It made me very sceptical of the whole operation, and of the quality of aftermarket head bolts.
Hopefully the bolts will either fail under retorquing or not, so I'll know if they're good or bad.
  #4 (permalink)
Old 09-25-2008, 12:35 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
It is not worth re-using. Go buy another set of head bolts. They are only $25 or so for that car.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
http://mistercmk.com/images/sig.jpg
Quote:
Originally Posted by tcbofade
I have no brain
  #5 (permalink)
Old 09-30-2008, 05:16 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Sure, you can reuse them. When you bolt a gate together, when you repair a wheelbarrow, when you want to add weight to the recycle box....
"Penny wise & pound foolish" is the man who invests his time and money in a repair and reuses tty bolts. Unless you want to do it over again a couple more times.....
  #6 (permalink)
Old 10-03-2008, 11:20 PM
Dad's Truck Dad's Truck is offline
Dad's Truck is starting off with a positive reputation.
Reusing stretch bolts will void whatever warranty you have on any re-machined or remanufactured part, and if they do fail will cause you to have to re-do everything you've already done. Don't use them.
__________________
Dave
'99 B2500 SE
'92 F-150 XLT - dad's truck- gone but not forgotten.
12/27/32-08/06/04
Sarah Palin doesn’t need a gun to hunt, because she can throw a bullet through an adult bull elk.
  #7 (permalink)
Old 10-04-2008, 03:55 AM
A bolt to the head
Warranty....?
Well after all the criticism of reusing these TTY bolts, I guess I'll just buy new ones.
  #8 (permalink)
Old 10-05-2008, 12:00 AM
mstngmikegt's Avatar
mstngmikegt mstngmikegt is offline
mstngmikegt is starting off with a positive reputation.
I have heard of people reusing them. I have never understood WHY? With all the work involved in swapping a head on any engine, why would you risk part failure and having to redo the whole job when the cost to use new ones is so minimal?
  #9 (permalink)
Old 10-19-2008, 11:50 PM
finn finn is offline
finn is starting off with a positive reputation.
Why reuse them?
I got my 92 Ranger for free from my brother in law: He had the engine replaced with a "factory reman" about 5000 miles before a head gasket failure: The "reman" didn't include new head bolts (corrosion on the shank of several blots) and the head popped off the right front bolt just above the block deck.
New bolts in the "reman" would have meant no free truck for me!
Alan
  #10 (permalink)
Old 10-20-2008, 01:04 AM
Those pesky TTY bolts
Hey, a vote for reusing the old bolts!
For bolts that I reuse, I always wire wheel them and insure they screw in by finger until they snug up to whatever they're holding on.
I see 302s (5.0) switched to TTY headbolts in the early 90s. The engine had no profound change though, and either style of bolts can be used on any small block, so long as they're all the same.
  #11 (permalink)
Old 12-02-2008, 08:50 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE. jimdandy has a good reputation on FTE. jimdandy has a good reputation on FTE.
I have re-used the bolts with no problems. If the bolt isn't damaged from rust, I run a tap in the holes, brush the threads on the bolt, and lube when putting them back in. If you don't do this, torque readings will be off anyway.
To properly do a TTY bolt, you don't use a torque wrench, you use a gauge. How many have one of these in your tool box. If torque wrenches aren't checked quite frequently, the can be off considerable. Also, all torque wrenches aren't the same quality.
The proper way to set torque on rod bolts is to measure stretch, but how many do that.:jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #12 (permalink)
Old 03-08-2009, 08:51 PM
blue beast's Avatar
blue beast blue beast is offline
blue beast is gaining momentum as a positive member of FTE. blue beast is gaining momentum as a positive member of FTE.
Unless you want the head to come off suddenly(probably not that violent) But if one
side pops the heads of the bolts off, I am pretty sure it will sound like a grenade
going off since the comb chamber is open. What is another $30.00 just think it will
make you feel better and not have to worry about one day crossing RR tracks and
all the bumps cause the weak bolts to break, Now you are stuck on the tracks!!
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
91 ford probe lx mtx The mighty vulcan 3.0
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!
  #13 (permalink)
Old 03-11-2009, 05:43 PM
You have to be kidding. It is not a matter of the bolts breaking, or "popping off," but rather do they still have enough clamping force to properly secure the heads to the block. They will be fine in a stock engine that is not used in heavy duty service. If used for heavy duty service, then new bolts would be used.jd
__________________
  #14 (permalink)
Old 03-11-2009, 06:20 PM
MisterCMK's Avatar
1994 Ford Mustang
My Garage
Quote:
I do.
I would much rather spend the $30 on bolts when the head is off than have to replace another head gasket down the road. Sure, the bolts might be just fine to re-use but there is also the chance that you get burned. $30 is not worth having to tear the engine down again.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
I have no brain
  #15 (permalink)
Old 03-11-2009, 07:23 PM
Quote:
My sentiments exactly. Do it once, do it right and be done with it.
__________________
Rides:
1995 F150 XLT 4X4, reg cab longbox , 144K miles, 5.0L/4R70W, 3:31's, 31X10.5's
(year round driver, winter snow biter)
1987 Mustang GT 5sp, 107K miles, GT40P's, E303, Explorer intake, 3.55's, just fun stuff
(summer driver, winter hermit)
Tags
302 , 91 , bolt , bolts , buy , f150 , factory , head , headgasket , method , replacing , reuse , reusing , torque , torquetoyield , yield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
