Better mileage at 80mph Vs. 60mph in a V10!??
#47
An engine runs more efficent and gets better mileage at its tork-curve whatever speed that may be. A gasoline engine has a low amount of torque and horsepower at low rpms and gas mileage suffers accordingly simply because the engine is not very efficent underload at low RPM. The mileage stated seems reasonable to me especially on flat ground.
#48
on
#49
Actually a V-10 is way under torque curve at 2000 RPM but very close at 3000 RPM. What you are failing to grasp is the power band at the higher rpm is more than the usual c/o drag and restiance. With a V-10 surely you must know that it fires on a 72 degree bank instead of the normal 90 degree bank of a typical V style engine. This is one of the reasons the V-10 likes moderate rpms. Between 2000 and 3000 rpms the torque would increase about 30% to 35% or so. So at this point I won't say what you have stated "is not" true" I'll let you decide that with the experience you have.
#50
#51
#52
on
I realize the engine is more in the power band at 3000 rpm but the power and mpg are two different things, the low rpms outweigh the lower power and rpms is what sucks the gas. If you don't believe it run around in second gear all day. The indy 500 cars are in the power band at all times but they aren't trying to save gas. (just threw that in). One more scenario; A vehicle at 90 mph would be more in it's power and torque range but out of it's mpg range mainly due to the higher rpms which is the biggest mpg killer so the rpms etc outweigh being in the "power curve".
#53
on
I just think you made a mistake or you had a huge tailwind. Everone in here is trying to get 15mpg+- but you got 17 at 82 mph and it is a known fact that all vehicles get less mileage at over 60+- no matter what engine/gear combo they have. Mainly because you are bucking more wind but the higher rpms are a gas killer also.
#54
Per the debit card statement, of $103.53 for 29 gallons at 3.57 per gallon.
Receipt for your debit card purchase
Hello Eagle Computers,
Thanks for using your PayPal Debit MasterCard®. Here's a receipt for your records.
Please keep in mind that the amount below is what the merchant temporarily holds until the transaction is complete - it may not be the final purchase price. You'll be able to see the final amount in your account history once the transaction is complete.
If you don't want to receive an email every time you use your debit card, just change your notification preferences.
Amount $103.53 USD
Merchant Kevin's Texas Quick Stop, Vega, TX
Please note that the name of merchant may be different once the transaction is complete.
do the math yourself.
Amount $103.53 USD
#55
$3.57 a gallon!? Wow...must be nice...
UrbanXX...do you even know WHY it fires at 72* intervals?
EXv10. It seemed you wrongly accused Ford of actually putting thought into fuel economy concerning the Excursion. Virtually zero thought went into designing the Excursion. And less than zero thought went into marketing it.
SteveEbey73742. Your findings are rare. Congratulations. Really. Impressive. Mileage.
All those folks who believe that the faster you spin an engine the less fuel it uses realize that's as crazy as a man with *****. C'mon, men don't have *****...right !?!
OH GAWD...
Originally Posted by EXv10
The factory designed the ex to get best mileage at about 2000 rpm and a little under 65mph.
OH GAWD...
#57
Monsta, the Ford V-10 is actually 2 five cylinder inline engines using a 5 throw crankshaft banked at 72 degrees to keep them even fireing. This is the principal of the Ford V-10 engine. Honestly I do not fully understand the cam design or head design on this engine. I understand the principal of the 2 five cylinder engine and 72 degree block design to make it into a V-10 but other than that I would need help. This engine is very simple in block design but very, very, complex in theory, especially in fuel flow, head, cam and timming. Way, way beyond me.
#58
on
OH GAWD...
OH GAWD...
#59
FWIW, the V10 is a 90* block (V angle) not a 72*. It fires at 72*.
An easier way of thinking about the V10 is that it is the 5.4L with an extra cylinder on each bank. The overhead cam design is really no different than any other but one head does employ a balance shaft to eliminate the vibrations that emanate from such a strange firing order. 72* firing in an 90* block makes for weird secondary vibration.
Its design does not make it "like moderate rpms". Most gas engine do. In fact, it makes 94% of its peak torque output below 2000rpms. The 2V was designed to generate 400ft lbs at around 1900rpm.
1900rpms is right around 70mph in OD. (Assuming stock tires and 3.73s)
#60
