Tranny/T-case slam
Tranny/T-case slam
So I have had my truck 2 weeks and i have noticed that if i get on the gas from 30-40 it reves and BAM slams like a SOB and also if i'm at 65-70 on highway and go to pass someone same thing... those are the only 2 speeds i have tried it at. The dealer told me its because the tranny is confused whether it should be in D or OD. I'm scared to even get on the gas? Anyone ever deal with this? i have 800 miles left on warr from dealer and am buying the Ford ESP warranty.
Any insight on this?
thanks
Gary
thanks
Gary
Yes, mine was intermitent
Here's the TSB:
Driveline - Slip-Bump on Deceleration or Acceleration
TSB 05-26-11
12/31/05
DRIVESHAFT SLIP - BUMP ON DECELERATION OR
ACCELERATION FROM A STOP
FORD:
2004-2005 F-150
LINCOLN:
2006 Mark LT
ISSUE
Some 4x4 2004-2005 F-150 (excluding Heritage) and 2006 Lincoln Mark LT vehicles build prior to 7/1/2005 may exhibit a rear driveshaft slip-bump concern on deceleration or acceleration from stops.
ACTION
This condition can be attributable to the slip yoke of the rear driveshaft having not been lubed when the vehicle was built or wear/flaking of the spline nickel coating. Refer to the Service Procedure.
SERVICE PROCEDURE
1. Remove the rear driveshaft per Workshop Manual Section 205-01. Be sure to index-mark the driveshaft during removal to maintain alignment during reinstallation.
2. Inspect the rear driveshaft slip yoke for the presence of grease. If no grease is present proceed to step "a" If grease is present proceed to step "b".
a. If the splines of the slip yoke are dry, but do not show any signs of wear, nickel coating flaking, or contamination, then apply 8 mL (0.27 oz.) of the new slip yoke grease, distributing it evenly around the bore. If flaking is found, then REPLACE the rear driveshaft.
Krazy
Here's the TSB:
TSB 05-26-11
12/31/05
FORD:
2004-2005 F-150
LINCOLN:
2006 Mark LT
ISSUE
ACTION
SERVICE PROCEDURE
Krazy
