Offroad & 4x4
shackle flip
Old 03-16-2001, 01:56 PM
72f100's Avatar
72f100
72f100 is offline
shackle flip
Does anyone know if anybody makes frame mounts to do a shackle flip on the back of my truck? I heard you can use the front spring frame mount and modify them to fit the rear of the spring, but I was wondering if there was a company that just makes the frame mounts.
Thanks,
Jeremy
Old 03-17-2001, 10:06 PM
85351ho's Avatar
85351ho
85351ho is offline
shackle flip
try offroad unlimited
i know they have them for chevys, so i bet they got em for frds
1985 F-150/351Ho/4wd/6inch with 33's
1979 f-250 429/4spd/6inchwith 36 inch buckshot mudders
on a quiet night your can hear a chevy (lol,you can watch a dodge) rusting away
Old 03-27-2001, 01:03 AM
mudinford's Avatar
mudinford
mudinford is offline
shackle flip
I have seen this done on an '78 and the owner swares he spent $10 doing it. I dont have the Mag infront of me but i will check on exactally how he did it. I THINK he got another back rear spring hanger and mounted it on the front of the rear spring. SO he had 2 rear spring rear brackets on the rear spring....whew! man that alot! but i will check tom.....
Dan "Mudinford" MacDonald
Rather be pushing a Ford than driving a Chevy.
Like A Rock......In Water!
Old 03-27-2001, 08:00 AM
72f100's Avatar
72f100
72f100 is offline
shackle flip
I believe I've seen that article. He took the spring mount that attaches the front of the spring to the frame and bought a pair of those and mounted them on the rear of the spring and attached the shackles to them, netting 4" of lift in the process. I guess I could have a junkyard knock me off a couple of those.
Old 03-27-2001, 05:29 PM
mudinford's Avatar
mudinford
shackle flip
[font size="1" color="#FF0000"]LAST EDITED ON 27-Mar-01 AT 06:29 PM (EST)[/font][p]You got it....it was that Bad "A" Camo Flatbed....nice truck......try that and let us know how it works...
Old 03-27-2001, 06:59 PM
traildawg's Avatar
traildawg
traildawg is offline
shackle flip
I'm not sure what your frame looks like, but you could probably use stock mounts from the newer F150's as they are already flipped. You can get them pretty cheap from ur local Ford dealer to boot.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
4.9L-Auto
Pro-Comp Stage-2 6" lift
Auburn Pro-Series Diff. w/4.30:1 gears
35x12.50x15 General Grabber MT's
http://www.geocities.com/ProjectTrailDawg
Old 02-16-2002, 08:46 PM
f350brocno's Avatar
f350brocno
f350brocno is offline
shackle flip
Old 03-13-2002, 01:29 AM
Mud Hogg's Avatar
Mud Hogg
Mud Hogg is offline
shackle flip
I drilled my rivets out of my stock rear hangers onmy 82 F150, flipped it over and bolted it back to the frame. I then added a 2in. shackle drop to it and removed the factory bump stop block.
Old 03-13-2002, 04:57 PM
motobub's Avatar
motobub
motobub is offline
shackle flip
Can't you just get longer shackels, or is that not strong enough?
Old 03-13-2002, 10:06 PM
mudinford's Avatar
mudinford
shackle flip
yes is would be stronger...but to the point that it would make a dif....who knows. BUT i woudl rather use a stock mount with a stock shackle that bolts up in a stock way to net me 4" of lift..all that for probly less then half for what you would pay for thoes longer shackles..not bad if you ask me.....
'86 Ford F-150 4x4 w/ a spooled mono Dana 44/a spooled 9" running 38" TSL. 300ci, Clifford Intake and Headders, .05" Milled Head with SBC valves, port work
500 CFM Edelbrock, Clif. 290* cam with Rhoads lifters, .040" TRW Pist w/ Moly rings.
Future plans: A draw through Twin(or big single) Turbo setup (to help with the upper end)
Old 03-30-2002, 11:10 PM
mrbassn's Avatar
mrbassn
mrbassn is offline
shackle flip
I have a 71 F100 4x4 and I did a shacle flip. I used the front spring perches off the rear axle of a donor truck and removed the rear hangers .AI replaced the rear hangers with the front perches and flipped the shackle .You can adjust how much lift you want. I could get about 7-8 inches of lift I only needed 4" so it works well also.Very inexpensive and not much work.I just torched them off a donor truck and torched the rivets off my truck,replaced the rivets with some grade 8's.It gives the truck a stiffer ride and no probs worrying about block slippage.Mr.B
Fullcrew7.3
Offroad & 4x4
11-18-2009 01:19 PM
Bender99
Offroad & 4x4
09-07-2009 02:39 PM
YoungMT Hick
Offroad & 4x4
06-21-2007 07:20 PM
rebocardo
07-08-2004 11:05 PM
Umpqua Arms
11-02-2002 11:10 AM
Quick Reply: shackle flip
