Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 09-22-2008, 02:11 PM
blkbeast blkbeast is offline
Garage is empty, add now
blkbeast is starting off with a positive reputation.
PEX Tubing in Processor
Anyone know how PEX plastic tubing would hold up inside a processor. I've got a central boiler outdoor wood boiler and it wouldn't take much to run a loop off my existing circuit to heat my processor. During the winter I've got it running anyway so thought that i may as well use it to heat my processor and wouldn't cost me anything. Just use the electric heating element for the summer. The water temp for the boiler is 185 degrees and figured that if i coiled a bunch of Pex tubing inside my processor barrel it would probably heat the oil up to at least 130 degrees if left overnight. Just don't know if the pex would hold up. Any thoughts???
thanks
Mike
  #2 (permalink)
Old 09-23-2008, 03:25 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud of
The problem w/PEX is it tends to get very brittle when exposed to heat and VO (and most likely B100). If your not putting much pressure in the PEX, it may be fine, at least for a season or 2. Take a peice of your PEX and leave it in the next couple batches and see what it looks/feels like!
I guess the worst case scenario is overflowing bio reactor w/water or ?? from boiler or contaminating the boiler fluid w/bio... either way doesn't sound too good for the boiler.
What about adapting to aluminum tubing or similar and putting that inside the drum? DON"T USE COPPER though!!
Why not wrap the outside of the drum w/PEX and then insulate over that?
How hot is the water from the boiler?
__________________
2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop View Post
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
Tags
diesel, flex, ford, fuel, pex, tubing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
