Ok, so I got a new set of tires for my truck. I got some 33x12.50R20 for my f-150. Oh yeah I traded my stock tires for these new nitto mud grapplers . Right now I am running 325-60/20 on nitto terra grapplers the truck and they did not fit so I have a spacer in there. My question is, will those new 33's fit on the wheel without the spacer. I was told that with my 3" level kit that those 325-60/20's would fit fine, but they did not. So, does anyone know for sure that these mud terrains will fit??!!
In order for you to run these tires I believe that you need a +18 offset which is very close to the 5.5" backspace on the stock rims. so you should be able to run the tires on the stock 20's with no problems.
