P0171 (System too lean bank 1), P0174 (System too lean bank 2) - Ford Truck Enthusiasts Forums
Old 09-21-2008, 11:06 PM
Octane's Avatar
Octane Octane is offline
Octane is starting off with a positive reputation.
I keep getting these 2 CEL codes. Ive already replaced the fuel filter. The truck doesnt start hard, doesnt lack power and isnt backfiring.
Old 09-21-2008, 11:33 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
These are really common. It is usually the PCV hose elbows that are cracked and sucking air, especially the one that connects to the rear of the intake manifold. The other common cause is a dirty MAF sensor.
Old 09-21-2008, 11:38 PM
Octane's Avatar
Cool. I'll have to look into those 2 things. Thanks.
Old 09-22-2008, 12:34 AM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
1: low fuel pressure
2: intake/vacuum leak
3: dirty/bad MAF sensor
Old 09-22-2008, 06:28 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
check the small 1/4 inch vacuum hoses on the drivers side on teh motor above the valve cover. i had 2-3 hot spots that caused the rubber to crack after 5 years... same code.
Old 09-22-2008, 07:57 PM
Octane's Avatar
One of the elbows had a little hole in it. Its looks like over time the rubber just got soft and cracked, causing the hole. I found a piece of hard rubber hose in my garage that is the same size and at least for now thats the fix I went with.
The truck seems to idle a lot smoother, so hopefully thats all it was.
Old 09-23-2008, 11:21 AM
whoduhmann whoduhmann is offline
whoduhmann is starting off with a positive reputation.
I just went through exactly the same thing, only I replaced the MAF sensor...for nothing. The part you're looking for can be found at a dealer for about $30. The repair took about two minutes....not even time enough to finish my beer.
Old 09-23-2008, 11:24 AM
xcquad66's Avatar
xcquad66 xcquad66 is offline
xcquad66 is starting off with a positive reputation.
advance auto parts carrys that elbow now...A LOT cheaper!
Old 09-24-2008, 06:54 PM
Octane's Avatar
Quote:
$30??? Whats it made out of...gold?!? I see that Napa lists it for $3.
Old 09-26-2008, 03:00 AM
LxMan1's Avatar
The dealer probably seels the whole assembly. Elbows, plastic tubing and PCV valve. That is what they installed on my 01 when it happened under warranty @ 32K miles.
Old 09-26-2008, 08:08 AM
that's correct LxMan1.
Old 09-26-2008, 01:20 PM
tallicakid tallicakid is offline
tallicakid is starting off with a positive reputation.
I when to NAPA and advanced and no one knew or could find what I was looking for. Anyone got the part number so I can take it with me? Its starting to p*ss me off starting the truck at every stop light.
Old 09-26-2008, 02:58 PM
Ron W., a very knowledgeable source, wrote this for me before I got mine from a dealer:
the Ford part number should be F75Z-6C324-JA and will cost you about $30.00 with the tax
I know what you mean about the stalling..but $30 and two minutes of my time and it was fixed. Good luck!
Old 09-26-2008, 03:39 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
I've been called alot of things but that ain't any of them.
I'm not a tech, just an ex-parts manager/warranty administator and still a do it your selfer. Glad I could help.
Old 09-26-2008, 05:27 PM
Do it your selfer is definitely the way to go. That simple little repair, in many shops, would've cost well over $100, I'm sure. This website is priceless!! Ron W, this Bud's for you.
'98 Expedition "System Too Lean", P0171, P0174 WhyFord Expedition & Navigator 161 01-04-2017 04:35 PM
Code P0174 system too lean bank 2... beekermartin 1997 - 2003 F150 29 01-24-2013 02:17 PM
Ford Expedition 2001 Codes P0174 , P0172 msradio Expedition & Navigator 2 01-22-2013 09:16 AM
Pulled code P0171 & P0174 on mazda mvp ??? oojbearoo General Automotive Discussion 6 03-01-2006 01:45 PM
Which side is bank 1, and which is bank 2? Roushians Ford Inline Six, 200, 250, 4.9L / 300 2 05-06-2005 10:07 AM
Tags
1997, 2001, 54, 99, bank, explorer, f150, ford, gmc, jimmy, lean, p0171, p0174, po171, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
