Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-21-2008, 01:21 PM
neil 95 e350 neil 95 e350 is offline
neil 95 e350 is starting off with a positive reputation.
Mixture adj for a N/A 460 EFI motor
greetings all. i have installed a Labonte h2o/alc injection setup in my BB 95 e350. i also installed an adj fuel pressure regulator. part of the water/alc injection theory for a N/A motor is to lean out the fuel mixture as you are replacing some of the fuel with the h2o/alc mix that has higher octane and a cooling effect on the intake charge. factory setting calls for 40psi fuel rail. anyone have any thoughts on leaning out the mixture? as in at what press setting you will actually start affecting the mixture?
any thoughts are appreciated. i have done h2o inj before, in fact i started doing it in the 70's, but never on a fuel injection engine...
thanx
neil
  #2 (permalink)
Old 09-23-2008, 10:29 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Freightrain is gaining momentum as a positive member of FTE.
I suppose, install a fuel pressure gauge and a a/f gauge and see where goes? A good wide band a/f would be best, but I suppose a cheaper one run by a $15 o2 sensor will give you readings to watch/compare.
I know from past experience of my friend racing his 87 Mustang with speed density computer that fine adjustments(lb or so) on the fuel pressure made changes in his times.
__________________
*signature delete option*
  #3 (permalink)
Old 09-23-2008, 12:50 PM
Conanski's Avatar
Conanski Conanski is online now
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Adjusting the fuel pressure will not produce sustained changes in A/F ratio, the computer will counteract the pressure change within a few minutes driving time.
The whole EFI system is based around the stoic 14.7:1 air/fuel ratio, the narrow band O2 sensors in these vehicles don't actually measure the ratio they just indicate if the mixture is lean or rich of the 14.7:1 baseline, and the computer is also programmed with this A/F ratio as the baseline. As a result producing a mixture leaner than this is not at all simple, a wideband sensor that can be programmed to provide the narrowband switching at the desired A/F ratio will be needed.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #4 (permalink)
Old 09-23-2008, 03:36 PM
thanx guys. paul-o, that was about what i expected. i expect most of my gains to come from additional timing advance - i am already running +5deg over base timing of +10, but have not done a lot of checking to see if the pooter is pulling it back and negating much of the "improvement".
neil
will report when the critter is back on the road.
  #5 (permalink)
Old 09-24-2008, 12:21 PM
When I had my new '96 F350 Dually 460/auto I bumped the timing(after pulled the pin out) and it ran WAYYY better when I bumped it up to around 13 degrees(seems stock was like 8). It wouldn't get outta it's own way when stock, it would actually squeal all FOUR tires out back after. I also removed the restrictions inside the air box tubes. Never saw any great MPG gains, only drivability improvements. Back then gas was CHEAP, so 10 mpg was fine.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
