Max AC blows through defroster?
Hey everyone. I just recently moved back to AZ, and got my '93 back from a buddy who's been babysitting it for the last 3 years. Now that she's really mine again, it's time to start fixing her up.
First off: my air. When I switch to Max A/C, after 1-4 seconds she starts blowing the air as if I've switched to defrost. It's cold air, which is nice, but I want it blowing on ME, not the windshield. Is this going to be repairable with the current HVAC head unit, or will I need to buy a new / newer one?
Thanks in advance for the help.
-Rob
-Rob
on
ac
Cj I will almost gaurentee that it is your vac line i live in hell with a zip code too I mean phoenix az had the same problem with my 93 to hot and dry here for the plastic vac lines welcom home if you can really say that about this place good luck its an easy fix just follow vac line thru wire harnes and thru fire wall and replace problem solved just wish we could fix dumb drivers here that easy lol
i have the same problem with my 93 bronco. it started earlier this summer. i suspect vacuum as well, but haven't had time to trouble shoot it. it seems to work fine on norm so that is where i leave it. what size engine is in your bronco? i have a 5.8. i need help with vacuum line mapping.
pickupman2002
09-24-2012 02:37 PM
CraigK
24
08-08-2010 07:43 PM
