Turn Right...It Stalls? - Ford Truck Enthusiasts Forums
Old 09-19-2008, 09:51 PM
gruberoliver gruberoliver is offline
gruberoliver is starting off with a positive reputation.
I have a 92 F-150 with a 302 and 5 speed.
Today in city traffic when I slowed down to turn right unto another street...it stalled. I didn't come to a complete stop...I was in sedond gear doing about 20 miles an hour. Took my foot off the gas crank the wheel to the right and while coasting thru the turn it died...It happed again a few files later...only right not left...
Any ideas? Thanks for the help
Old 09-20-2008, 04:27 AM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Manual transmission 302s of 1992 vintage have an idle-up/pressure sensor on one of the power steering hoses that causes the idle of the engine to increase when the steering wheel is turned when the engine is idling.
Does the idle slow when turning to the right?? Or is it unchanged or does it increase in idle speed?? Doesnt necessarily explain why second gear right turns would cause the engine to die-but it may if the engine speed/vehicle speed becomes low enough.And if right hand turns have higher resistance because of steering box/power steering issues. Is steering right from idle speed more difficult than steering left??
Old 09-21-2008, 12:27 AM
At idle when turning the wheel the idle doesn't change (left or right)...however, I've noticed that I normally don't turn left while moving since you are normally having to wait for traffic or light to change so I'm normally accerating when going left...
The sensor on the power steering hose...how do you check it?
Old 09-21-2008, 06:33 AM
ymeski56's Avatar
ymeski56 ymeski56 is offline
Der Postmeister
ymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputation
It shows up as a error code in the KOER scan & (located at bottom of steering colum, just above gearbox) w/engine at curb idle, sensor is bad if unplugging & replugging sensor has no effrct on idle.
Motor wants to stall when turning jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 03-21-2016 08:39 PM
Stalling Skyrobotv10 1994.5 - 1997 7.3L Power Stroke Diesel 6 03-02-2015 11:37 AM
Stalls in gear dstraw 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-26-2014 08:45 PM
89 351W stalling kevin206 1987 - 1996 F150 & Larger F-Series Trucks 6 08-01-2013 07:08 PM
351W stalls, help 46fordtruck Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 07-05-2003 12:49 AM
Tags
87, 94, dies, f150, f250, ford, motor, power, stall, stalls, steering, truck, turn, turning, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
