92 5.8 driviability nightmare - Ford Truck Enthusiasts Forums
Old 09-19-2008, 06:01 PM
wdavis wdavis is offline
wdavis is starting off with a positive reputation.
Angry 92 5.8 driviability nightmare
I have a 1992 e150 with a 5.8 l engine. 140,000 miles.just bought it at an auction. while driving it home it has a misfire cousing bucking. at an idel it surges and misfires. I thought a tune up would solve the problem.
I replaced plugs, wires, cap and roter, fuel filter. but no fix. so i cleaned egr and replaced a few bad vacume lines. no fix
a little fustrated i took it to a ford dealer. after 2.5 hrs diag time, i was told it needed a new pick up sencer and a icu. so a yanked the distributer and instaled a new pick up coil and also replaced the ig. control unit. but guess what? dident fix it.
so now i am guessing and replaced the tps dident fix it either.
nex i ran a can of seafoam through it and dumped some down the main vac line and let it sit for a while, but that dident fix it either.
this morning i took it to another shop and this mech. put it on the scope. when it missed, the scope showed that it was goin dead on all cylinders.
so i replaced the pcm relay, but that wasent it. so im gonna try the pcm itself. unless im wrong and just going to dump another 150 bucks for nada
please help!!!!!!!!!!!!
btw no check engine light at all
Old 09-19-2008, 06:52 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
does it act this way all the time or only after it gets warmed up? whats the timing set at? have you attempted to pull codes yourself using the paperclip method? Ford Fuel Injection is a great site showing you how and has loads of usefull info.
have you checked fuel pressure?
Old 09-19-2008, 06:55 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
You really should check the codes before throwing random parts at a problem, because as you said, you're really just guessing.
However, from the symptoms, I would guess it's s fuel pump. This is an e-series van, right? I don't know as much about the vans, but I know in 1990 they got the in-tank high pressure pump as opposed to the earlier external pump. I would guess your van is the same way. But you really need to check the fuel pressure as well as the codes.
I guess this was the long way to say, "do what he said".
Old 09-19-2008, 08:03 PM
thanx
Thank you for your help. the dealer said that the fuel pump and pressure regulator checked out fine. can i still pull cades if the cel dosent come on?
Old 09-20-2008, 09:29 AM
bucking
it starts misfiring as soon as the engine rpms drop after cold start warm up. checked for codes last night, but dident get any due to pulling out pcm to match one up at the parts store. im installing new one today, ill post the results
Old 02-14-2014, 10:17 PM
mech1's Avatar
mech1 mech1 is offline
mech1 is starting off with a positive reputation.
sorry to dig up an old thread but what was it? i have a 93 same thing, i had a spare motor and did full tune up, swapped dizzy and module, plugs wires cap rotor fuel filter tps oxygen sensor nothing, only things left are fuel pump (30 psi, 40 with vacuum line off) 18" of vac at idle, it bucks surges and stalls. thanks
Old 02-15-2014, 12:21 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Have you pulled codes?
Old 02-15-2014, 02:42 PM
mech1's Avatar
Yes, it has none. I have an OTC scanner
Old 02-15-2014, 05:14 PM
gman97005's Avatar
gman97005 gman97005 is offline
gman97005 has a good reputation on FTE.gman97005 has a good reputation on FTE.
Mine did the same thing but only at cruise and under a load, i did lots of work to the exhaust and that helped a lot but it still does it just not as often, i am leaning towards fuel pump or MAP sensor or both..
MAP sensor is the brains of S/D EFI which the 1992 E150 with 351W utilizes..
The fuel pump could also cause a problem like this, it can intermittently fail and cause drops in fuel pressure which would certainly cause bucking on a fuel injected vehicle..
Old 02-15-2014, 05:41 PM
mech1's Avatar
I have tried two different known good maps. Could be fuel pump but it holds 30psi at idle even when its missing, may try pressure tests at cruise
Old 02-16-2014, 04:06 PM
mech1's Avatar
Ok a friend had 96 f250 460, plugged in his ecm. All I can say is night and day!!!
Hope this helps others!
07 F150 up / down shifts randomly after new torque convert GregPeck 2004 - 2008 F150 2 01-17-2016 01:14 PM
IAC questions canman47 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 11-04-2015 11:19 AM
99, 250 V10 haveing speedo, abs and shifting issues. Richard Kenneth Bach 1999 to 2016 Super Duty 2 04-11-2015 10:52 AM
Fuel system 2: not reported iamvandemon 1997 - 2003 F150 5 03-17-2015 06:25 PM
86 f250 wandering at highway speeds waystro Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 33 09-15-2014 09:24 PM
Tags
1992, 58, check, codes, e150, engine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
