Does Magnaflow 16614 fit 2007 SCrew with 6.5' bed?
Performance Peddler lists it only for 2004-2006 (should I assume they just didn't update their applications?) and it says short bed - but is 6.5ft bed considered short bed - along with the 5.5 ?
Just want to be sure before ordering.
Thanks !
Thanks !
bcrab,
Are you sure? I called Magnaflow after posting and they said no.
However, you may be right, as I did have an '05 scab 6.5' bed that I installed the 16614 on, and I remember did get a (second) longer inlet pipe.
The install sheet for the 16614 says the 26" pipe is for early 2004 models.
That truck is the same as this, except for the longer cab.
So, this might be interpreted as 5.4L Crew Cab Short Bed EXCLUDING Extended Cab with 5.5' bed.
This is confusing. I'd love to pull the trigger, but want to be sure it will fit.
I'm thinkin it will fit.
Fits:
2004-2007 Ford F150
4.6L/5.4L V8
Extra Cab-Crew Cab/Short Bed (EC-CC/SB)
Magnaflow Part #
16614
Dual Exhaust Rear Exit
With my SCab I have a 6' bed and had to use the short pipe. With a SCrew you have a 5.5 bed and a little bigger cab, so if you use the long pipe it should fit?
Fits:
2004-2007 Ford F150
4.6L/5.4L V8
Magnaflow Part #
16614
bcrab,
I have screw with 6.5' bed. It's a foot longer than scab with 6.5' bed.
But I do agree, with that longer pipe, it will probably work. I had the 16614 on my scab with 6.5', and there was also about 4-6" of pipe clamped inside the exhaust tips. I used the shorter pipe for that install.
bcrab,
Oops, I missed the "excl" part of the description, and my feeble mind was translating 66" into 6.5'.
In the very worst case, you would have to have a welder move a hanger or two and a muffler shop change the piece of pipe between the Y pipe and the Magnaflow, but I'm betting it will fit your truck in the first place too.
Dont know if 08 is differant then 07 but I just put full Duals on my 08 XLT supercrewcab 5.4 4x4 6.5ft box/150"wbase.I should say I put Magnaflows on at the muff shop..total cast....249.00.....Drove it home and wasnt happy with the shifting,rpms ran high but when I got home I disconected the battery for a hour hooked it back up,started it up let the computor do its thing and man is it nice on the road....I should say its not much louder then the stock exhaust but sure made a differance in performance...OK it sounds great....
sorry rpxr400, I was thinking this might answer your question...guess not.
It's been about 2 yrs so I can't remember if I used the long or short section of piping.
I recommend you just buy the kit and go to a muffler shop for the install. maybe $100 for the install and the 1 ft section of pipe they'll need to include
