I thought you couldn't start the new trucks, that they had to be towed away if you wanted one bad enough. It doesn't seem cost efective to do all that just for a radio and lights, are all the air bags gone along with the dash?
Russ, whats the difference between the ravelco product and the factory anti theft device on my '03? I have the second key that plugs in underneath the steering wheel.
I don't know anything about the Ford 2nd key system. Does it disable the ignition/starting circuit?
When I pull the Ravelco 'plug' the engine immediately dies and cannot be started. It won't make a sound when I turn the key unless the ravelco 'plug' is in place.
