Sealers
Sealers
Getting ready to do some painting. Will be using PPG Concept single stage solid colors on two different surfaces. One surface will be bare metal (no body work) that has been painted with DPLF epoxy primer. The other surfaces are the original Ford enamel that has been thoroughly sanded and cleaned. I understand that the color can be applied directly over the DPLF as is. However, the enamel surfaces should be sealed and I have seen two versions saying use the DPLF (store) and something like K36 (car forums). Are both right in their choice or is one more appropriate?
Going through archives I saw that the PPG V-Seal Acrylic Urethane Sealers would be best to use on the cured and sanded oem surfaces due to laying out nicely. At least that was the opinion from someone who sold paints like PPG.
