Transmission shifting hard - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-18-2008, 08:09 AM
Roadhog123 Roadhog123 is offline
Roadhog123 is starting off with a positive reputation.
Hello everyone. My truck has started shifting hard recently. It started doing it on the shift from 1st to second and now it seems to be hard shifting on all gears. If I am stepping on it at all, it feels like it is going to drop the tranny in the road. This is especially true while at highway speeds when passing a car or similiar. I bought the truck used and do not know if it has a chip or a kit. I don't even know where to look for a chip. I did read about a kit that will "firm up" the shifting...maybe it had one of those and it has become defective, not sure. The truck has 300,000 miles on it and I drive 90% highway miles at 70-75mph. Any input would be greatly appreciated.
Thanks
Old 09-18-2008, 09:01 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Since the problem started recently, I don't think it is PCM related. Sounds more like a sticking valve or spool. There is a plunger in the line pressure modulator that could be sticking and 'boosting up' the pressure.
Have you changed the fluid lately?
Old 09-18-2008, 09:32 AM
Thanks for the quick reply. It has been about 70K since the fluid was changed. Do you think that is the place to start?
Old 09-18-2008, 09:42 AM
mueckster's Avatar
With that many miles, it would be a good place to start. Have you ever done the transmission flush (instructions by Mark Kovalsky) or had it flushed?
Old 09-18-2008, 09:59 AM
No flushes. Just a filter/fluid change once. Where can I find the Kovalsky flush thread?
Old 09-18-2008, 10:05 AM
zack7.3's Avatar
zack7.3 zack7.3 is offline
zack7.3 is gaining momentum as a positive member of FTE.zack7.3 is gaining momentum as a positive member of FTE.
Old 09-18-2008, 10:06 AM
DemonRace6's Avatar
DemonRace6 DemonRace6 is offline
Hi!
DemonRace6 has a very good reputation on FTE.DemonRace6 has a very good reputation on FTE.DemonRace6 has a very good reputation on FTE.DemonRace6 has a very good reputation on FTE.
Changing the fluid and a flush is definitely the place to start, my transmission shifts OK and after a flush and change I can really feel a difference, I change my trans oil quite often, almost every two oil changes.
Old 09-18-2008, 10:25 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
70K is a bit long between flushes/filter changes. 35K is what's recommended. A complete flush and filter change will get all the fluid out too.
Old 09-18-2008, 10:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Actually, 30k is the recommended interval.
Old 09-18-2008, 10:51 AM
How do I know whether I have a E40D or a 4R100 or a 4R70W? It is a 1999 7.3 F250 Super Duty Powerstroke.
Thanks for all the help so far.
mueckster's Avatar
You have the 4R100.
Old 09-18-2008, 03:32 PM
the guy at advanced auto says he shows no 4r100 for this make and model. The only filter he has is the E40D. Are the numbers on the tranny anywhere? I would like to be sure what I have before taking it apart. Thanks
Old 09-18-2008, 03:38 PM
Hit it!
Go to another auto parts store. It's a 4R100 tranny.
Opps, sorry Mark, you are absolutely right - 30K between flushes. I was mistakenly thinking that he was exactly 2 times over the limit on mileage. duh. At least my math skills were working just not my maintenance skills.
Old 09-19-2008, 01:17 AM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
I noticed in the article that was posted that it says to use mercon instead of mercon v, but didnt they phase mercon out?
Old 09-19-2008, 02:25 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
They re-formulated the current Mercon to be compatible with all the internals of a 4R100.
This reminds me, time to pull a tranny oil sample for Blackstone. Thanks!
Yes, it's cheaper than an oil change, and more environmentally-friendly than a complete change-out.
Pop
OD off button? deputydog03 1999 to 2016 Super Duty 15 03-16-2016 10:42 AM
E4od shift improvements ?? Dutter 2 1987 - 1996 F150 & Larger F-Series Trucks 11 12-18-2015 02:44 PM
Transmission problems....Sooo lost Green-Monster 1999 - 2003 7.3L Power Stroke Diesel 19 04-28-2014 09:52 PM
Truck started shifting hard turnkyle 1987 - 1996 F150 & Larger F-Series Trucks 12 10-11-2011 10:59 AM
E4OD Shifted Hard scottw1 Clutch, Transmission, Differential, Axle & Transfer Case 2 01-16-2009 05:17 AM
Tags
12, 4r70w, 60, accumulator, at, drive, e40d, ford, forums, hard, replacement, shift, shifting, transmission, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
