VIN/Manu. Label???
VIN/Manu. Label???
I am currently looking at a 2006 F-150 4X4 Supercab with 8' bed (WB=163")
XLT
36079mi
5.4 3V EFI FFV V8
Tow Pkg.-front tow hooks, skid plates,...
plus some electronic goodies (windows, driver seat, CD, keyless entry, etc.)
....and they're asking $18000 for it
What ya'll think?
ALSO, they are not sure the rear end on it and not quick to research it but I got them to send me a picture of the manufacturer's label from driver's inside door frame with VIN and all that code on it. I haven't been able to find a site or means to interpret all the coded numbers on the label, for newer trucks at least. I have found some for 60's-70's but that is it.
Any Suggestions?? Links to site that will decode it for me? I know this is a rare truck setup with extended cab and long bed but anyone know std rear end for it?
Anything else on truck I should make sure to watch out for?
I am going to check it out on Friday...
Thanks!
XLT
36079mi
5.4 3V EFI FFV V8
What ya'll think?
Thanks!
how many lugs does it have? pretty much the only 8 ft bed you can buy is the Heavy Duty I believe. If it has a 7 lug axle, then you have the Heavy Duty 9.75 axle with 4.10 gears
4.6 motor = 8.8 pumkin with 3.55 gears being predominant
5.4 motor = 9.75 pumkin with 3.73 gears being predominant
all 4x4's have the front 8.8 axle
EDIT: Monsta is right...about $2k overpriced.
Thanks for everyone's inputs!!
I did finally find a way to decode the rear end gear ratio code.
The code is B5 and equates to a 4.10 i am pretty sure... which I guess you say is the 10.25"....that'll be a gas hog for sure!!
Thanks again....and also if you have any other things you think I should check out on the truck this Friday...please just send it my way!
I'm pretty sure, when you do some digging on ford's website, here's what comes up for the HD payload package:
"Includes LT245/70x17D BSW all-terrain tires; high- capacity 17" 7-lug steel wheels; heavy-duty shock absorbers; 72-amp battery; upgraded springs, radiator and auxiliary transmission oil cooler; 10.5" gear set; standard 4.10 axle (optional 4.10 limited slip). Requires 5.4L 3V V8 gas engine. Available for Regular Cab Styleside with 8’ box (145" wheelbase) or SuperCab with 8’ box (163" wheelbase). 4x4 model requires 35.7-gal. fuel tank, NA with 5.4L FFV engine"
On their "build your own" site, you can't get a 163" wheelbase truck without the HD package.....
One question tho, you say the HD package with all those options on a Supercab F-150 and 8' bed with 5.4 is not able to be the FFV 5.4? I just ask because the dealer says it is FFV capable and yet I've seen other articles where people can't even tell/figure out whether their truck is FFV capable or not b/c its quite obscure I take it?? I just want to make sure whether it is or not....do you know how to tell??
Thanks
Yes, I do know how to tell...mine's an FFV...this is what the owner's manual says....
"To identify if your vehicle is an FFV, it may
be equipped with a yellow fuel cap with the writing “E85/Gasoline”, or
check if there is a label on the fuel filler door, or check your VIN. When
checking the VIN, look for the engine type identifier (8th character). If
your vehicle is an FFV, then the character will be labeled as a “V”"
- Page 339, 2007 Owner's guide
In short...the easiest way is to look on the fuel door, should say something like "Gasoline or fuel ethanol only", if I remember right. I believe the FFV engine is available in the HD package, but I'm not sure...
