Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > West Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: msgtg
  #1 (permalink)
Old 09-16-2008, 04:59 PM
pmasley's Avatar
pmasley pmasley is offline
I Be The Instigator
Garage is empty, add now
pmasley has much to be proud ofpmasley has much to be proud ofpmasley has much to be proud ofpmasley has much to be proud ofpmasley has much to be proud ofpmasley has much to be proud ofpmasley has much to be proud ofpmasley has much to be proud ofpmasley has much to be proud ofpmasley has much to be proud of
Paul Masley
Cool Need A little Help
Due to my present medical condition, I need to find a local FTE'r near Charleston to help me figure out what is wrong with my stroker. I cannot climb over it doing the test that needs to be done.
It still has the loss of power. Like it is not getting enough fuel. The mileage has dropped down into the low 10's. All filters and service work has been done with no better result. I was going to take it to Jody, but he has moved down to lower Georgia. That is just too far for me to drive with my medical problems.
Hey, just to get it fixed right I would pay someone.
Is there anybody out there around me that can give me a hand?
__________________
Paul
No truck at the moment, but I do have a 2005 Crown Vic LX Sport
FTE FOLDING TEAM MEMBER of 53449
Member "Boy you ain't right club#7"
  #2 (permalink)
Old 09-16-2008, 09:47 PM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
1999 Ford F-250
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
Give me until next week and I may be able to help. I will let you know dates/days this weekend. If someone else can get to you sooner that would be OK.
Rod
__________________
Toby Wan-Knobey
WV Chapter Member
This is my RCA dog look!
  #3 (permalink)
Old 09-16-2008, 10:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Paul I wish you were a bit closer.
Working 12's right now has me a little short on drive time.
I would be glad to help, but you would have to tell me what we need to do and check.
I am right at home on an IDI, but I would be lost on a Stroke.
Hammer and allen wrenches for tools, right?
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 09-17-2008, 12:07 PM
pmasley's Avatar
I Be The Instigator
Paul Masley
Thanks Rod and Dave.
I just really don't know what it's problem is. There are no codes. It just does not have any power. Like the turbo is shutdown. But I can hear it spin up. It is like that it is not getting enough fuel. Almost floorboard at 80 on the interstate. It should not require that much. It acts like that old 302 I had in the F-150 4WD. Sick.
Any ideas would be great.
__________________
Paul
  #5 (permalink)
Old 09-17-2008, 08:33 PM
1997 Ford F-350
My Garage
You getting any black smoke?
Anything with the turbo or boost leaks should have you rolling black smoke.
Fuel related, I would be totally lost on that side.
HPOP maybe?
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #6 (permalink)
Old 09-20-2008, 11:27 AM
pmasley's Avatar
I Be The Instigator
Paul Masley
No smoke, just no danged power. That 7.3 should sink yur but in the seat under full throttle. It just sags the springs. And the mileage is the pits. I just cannot figure it out.
__________________
Paul
  #7 (permalink)
Old 09-21-2008, 02:58 PM
1997 Ford F-350
My Garage
That sounds like a fuel problem to me.
Steel HPX, that is the fuel high pressure crossover line isn't it?
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #8 (permalink)
Old 09-21-2008, 06:32 PM
pmasley's Avatar
I Be The Instigator
Paul Masley
Dave, that is the oil pressure stablizer line from the left head to the right head.
I am also leaning towards the fuel pump on the rail. It looks like it has been replaced before I got the truck. I am trying to locate a gauge that I can tap in the line to see what pressure the pump is pushing. I am also looking at a possible boost problem. The tach just swings too fast once it gets over about 2200 rpm. I think that the boost is suppost to start right after 1400. It has to be something between the two or maybe both.
__________________
Paul
  #9 (permalink)
Old 09-21-2008, 07:34 PM
1997 Ford F-350
My Garage
OK, from my reading I new it had something to do with the fuel injection.
With the oil pressure even on both heads all the injectors should be firing the same.
I think I would look at fuel pressure to the injectors next.
On turbo engines, a boost problem usually shows as excessive black smoke.
The fact you have none tells me you boost is fine.
So if you have air, the only other thing you need is fuel.
If you have more power at higher RPM, that could still be tied to a weak fuel pump.
Not enough at low RPM, but closer to what you need at higher RPM since the pump is turning faster.
IDI logic on a Power Stroke....that might be dangerous.
Rod is probably hiding and taking notes on all this.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #10 (permalink)
Old 09-21-2008, 08:41 PM
pmasley's Avatar
I Be The Instigator
Paul Masley
Well, it is really not more power, but it seems to spool up the RPMs a lot faster once it gets near 2200. I may have a boost leak at that internal turbo overboost valve. I am planning on tightening that thing down to see if it helps.
I am thinking that it is either the pump or that damn screen in the tank causing the problem. It did not start until the government went to this low sulphur fuel. I have heard some rumors from the dodge boys that it has messed with the cummings fuel tank pump clogging the screen. Maybe time to drop the tank and just do the hutch mod.
__________________
Paul
  #11 (permalink)
Old 09-25-2008, 06:34 AM
pmasley's Avatar
I Be The Instigator
Paul Masley
Dave, I still cannot figure it out. Yesterday, the damn thing started loping like a cammed gasser. It did it for about five minutes than quit. No Check Engine light and no code.
After that it ran fairly decent. Do you think the screen may be clogged in the tank?
__________________
Paul
  #12 (permalink)
Old 09-25-2008, 10:32 AM
1999 Ford F-250
Paul, Sorry but had too much happen this week. I will get with you ASAP. No have not been hidding.
Sorry again
Rod
__________________
Toby Wan-Knobey
WV Chapter Member
  #13 (permalink)
Old 09-25-2008, 05:46 PM
pmasley's Avatar
I Be The Instigator
Paul Masley
Talking
Quote:
Sorry again
Rod
Thats alright Rod. I am just nursing it along. I love that diesel, but now I think I should have kept the 85. I could fix most things on it with a hammer and a screwdriver. Just kidding.
__________________
Paul
  #14 (permalink)
Old 09-27-2008, 12:06 PM
1997 Ford F-350
My Garage
Paul, looks like you are aware of why I like my 86.
The hammer and screwdriver tool kit worked on the 86 as well, but the IDI also requires a 5/8" wrench.
Most of the issues with ULSD for the IDI motor are lack of lubrication from the fuel.
I have noticed lower MPG.
Power numbers are down using the Butt O Meter dyno.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #15 (permalink)
Old 09-27-2008, 12:55 PM
pmasley's Avatar
I Be The Instigator
Paul Masley
Red face
That is what I am feeling too. The Butt Meter and the Metal Pedal says something is wrong.
__________________
Paul
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
