Squeaky truck
Squeaky truck
My driver side front suspension is squeaking like crazy. It isn't a rotational sound as it even makes noise when the truck is stopped when I step out of it. I greased the bushings on the upper and lower control arms as well a lubed up the shock bushings. I also greased the upper and lower ball joints. After all of that I still got the same squeak. When I lay under the truck and push it up and down it almost seems like it is coming from the shock, but I have never had a shock squeak before. Have any of you ever heard of this problem? Can shocks squeak?
Any help on this would be greatly appreciated as I am at my whit’s end trying to figure this out.
I just changed out my sway bar link bushing yesterday, much quieter now. My problem was easy to spot, the bolts that hold the links on were dangling under the a-arms due to the bushings completely separating and falling off. I hope that is your problem, very easy to fix yourself compared to ball-joints.
