2005 6.0L cold start problems - Ford Truck Enthusiasts Forums
Old 09-16-2008, 03:14 PM
kdi500 kdi500 is offline
kdi500 is starting off with a positive reputation.
Can anyone tell me why each winter I need to take my truck in because it will not start properly when cold? I have been told that it has something to do with the computer. Is it an adjustment that can be easily made or is it yet another flaw in design? I live in Arizona and the coldest it gets is around 30 degrees. The problem occurs each year when temps go down below 65. If it starts, it runs very rough and blows lots of black smoke until it warms up. Then it's fine for the day, until the next morning. The dealer said the glow plugs are fine and I give them time to warm before cranking it over. Any ideas?
Old 09-16-2008, 03:16 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
are you letting the glow plugs stay on long enough before cranking it? Does the indicator light go out indicating it is ok to start?
Old 09-16-2008, 03:21 PM
It's not the glow plugs
Old 09-16-2008, 04:09 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
You need to find a REAL diesel mechanic! Hopefully you have another Ford dealer that has a certified diesel mechanic on staff. What's the last time they flashed your computer?
Old 09-16-2008, 04:43 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Most likely you just need the latest flash with inductive injector heating, that solves most of the cold start problems. I think they blow white smoke if its injectors though, but I could be wrong. Could also be a turbo or EGR problem.
Old 09-16-2008, 05:46 PM
shdwlkr's Avatar
shdwlkr shdwlkr is offline
shdwlkr is starting off with a positive reputation.
My 2006 was having a little trouble firing up when it was really cold talked to my ford dealer mechanic and we flashed my computer with the latest update for starting and now I can start it down to around zero with no plugging it in. Just my situation might not be your problem
Old 09-16-2008, 07:56 PM
Thanks for the reply, fellas, but i believe the dealer flashed the computer both times this has occured. It works for the winter but each winter it's the same thing. What is the expiration on this fix, 1 year? The temps are just barely starting to cool down, in the 70s for the low and I already feel this problem reoccuring. Any other thoughts? Thanks.
Old 09-17-2008, 09:52 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Thread moved to the 6.0 forum, good luck!
and WELCOME to FTE!
Old 07-09-2009, 06:49 PM
huntinfishn huntinfishn is offline
huntinfishn is starting off with a positive reputation.
kdi, was wondering if u found out the problem,i am havingthe exact same problem now. funny thing i am in arizona as well, maybe the air is bad here lol. thanks
stan
Truck runs too cold. Why? 351Cleveland C4 1999 - 2003 7.3L Power Stroke Diesel 34 01-09-2015 06:10 PM
Chapter Leaders Boots are a fine source of chewy rawhide... Greywolf General Chapter Discussion 34 07-30-2014 04:51 PM
03 6.0 Diesel problems rockenr 6.0L Power Stroke Diesel 12 09-18-2013 04:00 PM
p1450 code 99 expedition Budda1234 Expedition & Navigator 3 06-15-2013 02:48 PM
1999 Ford F-250 starting problems BigT2006 1999 to 2016 Super Duty 4 08-03-2006 01:50 PM
Tags
60, cold, ford, problems, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
