2007 Expy EB SWB -Loud Click from Center Console - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 09-15-2008, 10:32 PM
rhc43 rhc43 is offline
rhc43 is starting off with a positive reputation.
About a month ago I began hearing a very noticeable click from inside the front area of the center console, right around the shifter. The only time you hear it is when the engine is running, the shifter is in park and you step on the brake like you are getting ready to shift out of park. Has anyone else experienced this problem and were you able to fix it? Thanks!
Old 09-15-2008, 10:42 PM
nfntruth nfntruth is offline
nfntruth is starting off with a positive reputation.
That is the interlock that prevents you from taking the vehicle out of park without the brake pedal depressed, its supposed to click. Although it shouldnt be too loud...you can feel it if you hold the shifter when you press the brake pedal.
Old 09-16-2008, 11:28 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I have that but I wouldn't call it loud. I would have to listen for it closely to tell. Not a problem though.
Old 10-07-2008, 11:24 AM
berry1234's Avatar
The EL has been out since 07 model year.
Tags
2007, console, expedition, ford, interlock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
