Check Engine comes on and cuts out/hesitates
on
The Symptoms sound like a CPS. If you have a spare put it in and try. if you don't have a spare buy one and replace yours and if it doesn't fix the issue you now have a spare.
The CPS is on the front of the engine at about 11 o'clock around the crank pulley. You can see it from the top but I change them from the bottom.
on
Terminator Engineering
Add the $30 option at the bottom of the page for Contribution/buzz test and you can pull codes and see data that you will need to diagnose most every issue you may have.
I have one and love it!
That's a cheap price for a good scanner. Some actrons will scan a diesel...
But You get what you pay for.
You could have it scanned for 50-100 bucks every time you need to and be at the mercy of the operator to boot (bad info)
If you are going to keep your truck...a good scanner will pay for itself
in the long run. You could sell it with the truck or by itself when the time comes to recoup some of your $$.
Actually, that's only half true. They will not say it's compatible
with a 7.3 for legal reasons....but some of their products will read
7.3 OBD2 codes....just not all of them. I Had a local autozone
scan my truck and it worked (with my help). It's going to depend on the counter help too,
they gotta know what they are doing.
IDM???
It starts and runs, but it is like it's down a few cylinders and the check engine light is on.
What is it like when a bank of injectors go out. Maybe melted wires or something.
I did have to drive it 30 mi home the other night hoping I did not damage anything. But it does still start very easy.
What is the PCM designation, e.g. OBD 1, OBD 2, etc? I cannot find anywhere where it would tell me. Usually it would be on the emissions label.
Your truck may have both connectors.
You can send your PCM (or buy and exchange) to Dp-tuner and they can reflash
your computer to a 96 or newer OBD2. It runs $75.
OBD1 connector is under the hood
OBD2 is under the dash
The red connector on the left is OBD1, the black one on the right is OBD2.
