1989 f350 7.3 fuel system - Ford Truck Enthusiasts Forums
Old 09-15-2008, 06:25 PM
drewdole1 drewdole1 is offline
drewdole1 is starting off with a positive reputation.
looking at the service records on this uhaul i saw an electric relay for the fuel pump or fuel system had been replaced. i thought the fuel pump and fuel system was non electric. any insight??????
Old 09-15-2008, 07:45 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
If it has 2 tanks there is an electric switch on the frame just ahead of the tanks.
Old 09-15-2008, 07:54 PM
just one tank
Old 09-15-2008, 10:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
No relay on the fuel system in stock form.
The IP and lift pump are both mechanical.
Old 09-15-2008, 10:42 PM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is gaining momentum as a positive member of FTE.
Maybe they put an electric fuel pump on it?
84 F-150 with Carb.. Manual or electric fuel pump? reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-09-2013 02:21 PM
huge problem about to light this truck on fire biggyfan1 1973 - 1979 F-100 & Larger F-Series Trucks 48 10-31-2013 08:26 PM
my facet electric fuel pump drewdole Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 04-10-2012 08:03 PM
Electric fuel pumps 72f2504x4390 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 06-15-2007 09:02 PM
Auxillary Fuel Tank bbarton 1999 - 2003 7.3L Power Stroke Diesel 4 01-22-2001 07:07 PM
Tags
1989, 2003, 73, 89, complete, f350, ford, fuel, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
