EBPV weirdness
EBPV weirdness
I have been meaning to post this question for some time now but keep forgetting I've been running with my EBPV unplugged because if I leave it plugged in, it seems to want to shut on me when I let off the go pedal (or at least it was doing that). I haven't messed with it again for quite some time, but with the cold weather coming I'd like to plug it back in for the high idle in the morning. My EBPV tube was clear when I removed it, I cleaned the sensor when the tube was out but didn't remove it because I didn't have the right socket. What could cause the EBPV to shut under decel?
It's not going to go into hi idle until it's about 35-45° and like ron said high idle will work regardless of the EBPV being connected. It just won't be as loud.
Could it be the AIT?
I still don't think there is anything wrong, has your truck go into high idle at 40°? Mine has not. I though I have had mine come on above freezing, so I'm not positive on the temp, but it will go there if there is extended period of below 32°.
I wouldn't be to worried about the high Idle, it will come naturally.
Chase have you put your truck through a winter yet? If not I wouldn't be to concerned.
Jason I'm more concerned that the EBPV seems to shut itself when I let off the go pedal than the truck not going into high idle. With it unplugged I haven't had a problem, but when it was plugged in last I had to pull over and unplug it again because even slightly letting off caused it to shut.
I believe so. Here are the related codes:
<LI itxtvisited="1">P0470 Exhaust Back Pressure Sensor Circuit Malfunction <LI itxtvisited="1">P0471 Exhaust Back Pressure Sensor Circuit Performance <LI itxtvisited="1">P0472 Exhaust Back Pressure Sensor Circuit Low Input <LI itxtvisited="1">P0473 Exhaust Back Pressure Sensor Circuit High Input <LI itxtvisited="1">P0476 Exhaust Pressure Control Valve Maffunction <LI itxtvisited="1">P0476 Exhaust Pressure Control Valve Performance <LI itxtvisited="1">P0478 Exhaust Pressure Control Valve High Input
