Porting D3's - Ford Truck Enthusiasts Forums
Porting D3's
Old 09-15-2008, 01:17 PM
johnsf's Avatar
johnsf johnsf is offline
johnsf is starting off with a positive reputation.
Porting D3's
I want to port some d3 heads this winter and was wondering about the exhaust ports. I know that this is the weak part of these heads and was wondering if this "bump" that is in the bottom of the port when the head is lying flat on the milling surface is the place to start.
Any help or idea's?
John
Old 09-15-2008, 01:19 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Sure, grind it off.
Old 09-15-2008, 01:52 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
go to reincarnation-automotive website, pay the $25 regristration fee and it gives you the web's ultimate authority on porting D3's heads. step by step instructions from probably the best porter of stock heads out there.
i spent the $25 and did my D0VE heads. he shows where and what to grind and where not to grind.
i would recommend that site if you are going to do the porting. best $25 you will spend.
rgds
Mike
Old 09-18-2008, 10:49 PM
WILDEBILL308 WILDEBILL308 is offline
WILDEBILL308 is starting off with a positive reputation.
That $25.00 can save you the cost of a head. Knowing whear not to grind is as inportant as whear to grind. Doing it right is much easier with Scots info.
Bill
Old 09-21-2008, 10:11 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
DONT GRIND THAT BUMP!!! Actually called the "tongue"... thats there for a reason. The exaust ports are "ramped" up like that to increase air velocity. If you have a good set of heads ported profesionally, they actually add material to the floor, and grind on the roof of the port. Porting is a fine art. You want to make the head more efficient, not just bigger. Also, around the valves, you could do a bit of smoothing and unshrouding, but make sure to take the same amount of material out of each chamber. The best thing to do if youre unsure about porting is stick to port matching. Get the intake and exaust gaskets you will use, scribe the ports where the edges of the gaskets are. then make the ports flush to the scribe marks.. keep everything smooth and rounded. This is a really good trick on the intake. When doing and intake you want to keep everything "burred" up and rough, this helps atomize the fuel in the air. while on the exaust side, you want to polish or at least make it as smooth as possible, same with the combustion chamber.
E7TE head porting 1Fastang Performance & General Engine Building 5 12-26-2008 11:03 AM
Plugging EGR port on E7TE Heads... Jrock909 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 02-04-2007 09:04 PM
smog bumps in heads johnsf Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 01-25-2007 12:49 PM
wanted- pictures of head porting C8AE-H woodsrider505 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 01-02-2005 04:50 PM
AW CRUD!!! Messed up my 460 heads porting . . . Tsaven Nava Performance & General Engine Building 9 08-12-2004 02:39 AM
Tags
460, d3, ford, heads, john, johnsfyahoocom, ported, porting, portting, wright
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
