2002 F250 V10 Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-14-2008, 08:53 PM
rceagle1a rceagle1a is offline
rceagle1a is starting off with a positive reputation.
I traded my 2002 F250 last week because of a SERIOUS issue I had. I had 4 out of 10 Exhaust manifold mounting studs broken on the Passenger side and one on the Drivers side. It was going to take removing and dismantling the engine to fix it. I was getting destitute from the gas bills so I decided to trade instead of fixing it. I know, I know: I shouldn't trade a problem but I know i'm not the first or last to do that. I had gotten quotes from 400.00 to cobble it to over 3,000 for new heads. I just want to make you guys aware that this problem is around and it is EXPENSIVE to fix.
Old 09-14-2008, 10:39 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
It's not that expensive. Check out the V10 forum and you'll see many have done the repair themselves, with the engine still installed.
Old 09-15-2008, 08:07 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
You got some VERY bad advice.
It might take a few shop hours to fix it, but it was fixable with the engine still in the truck, and the heads do not need to be replaced.
It's a well-known issue, too.
Should have visited an exhaust shop.
Old 09-15-2008, 04:19 PM
Heavy_Metal Heavy_Metal is offline
Heavy_Metal is gaining momentum as a positive member of FTE.
Only four???!!! I had seven and fixed it in under a day, by myself. It cost me, with the price of a new set of headers under $250. I'm sure the dealer marked your value down too for something that was probably easily fixed.
Old 09-15-2008, 04:26 PM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
i noticed that this is your first post...you should have posted a question about your studs before you traded it in.sounds like the dealer hosed you.welcome to FTE.
Old 09-15-2008, 05:58 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Yeah, sorry to hear about your situation and bad recommendations you received. Most of us fix them ourselves for as little as the cost of a new stud and nut - like $5 per stud.
Old 09-15-2008, 06:52 PM
thanks for the responses
If I had known about this site I prolly would have fixed it. But the truth in the matter was and still is i didn't need the super duty for what I do with a truck. An F150 is fine for me. I have a 2004 F150 Super Crew now with a 5.4 and i have an edge Evolution coming as well.
Old 09-15-2008, 07:15 PM
Err, I believe the 5.4 comes with the same exhaust studs. But that's OK, because now you know about this site and if the same problem comes up, you've got help!
And the 150 is a great truck, and good on you for recognizing what you NEED versus what you WANT. If I didn't haul so much, I'd be in a "half ton" as well. Stick around!
Old 09-15-2008, 09:49 PM
I plan to stay around for a long time. I Loved my Super Duty like a child. It was the most awesome vehicle I've ever owned. I loved the Ferrari like quality the exhaust had but I didn't love the gas mileage. I have a 31ft TT that I will pull with the F150 but it doesn't go long distances and I'll be able to monitor trans temp with the Edge box. I also plan to put Cat Back Duals on this truck as soon as I can.
Infamous stripped spark plug mongovb Excursion - King of SUVs 10 10-04-2015 10:18 AM
im in a pickle and want some opinions isaac3384 1973 - 1979 F-100 & Larger F-Series Trucks 14 01-26-2014 06:12 PM
Gas VS Diesel the real world truth ironman77 1999 to 2016 Super Duty 177 09-23-2013 05:33 PM
Trading F250 for 08 Edge??? foxv10 Crossovers 6 09-19-2013 07:05 PM
400m Overheating ect... Colorado78F150 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-21-2011 09:52 PM
Tags
2002, ford, problems, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
