You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
i know that this has been touched b4 and ill keep looking. can i convert to mass air using the 88 to 93 mustang computer assuming its not already. im not worried about the tranny because it not in stock truck and not using stock tranny. i just need to run the engine and the mass air conversion using the mustang computer seems to be the best way. let me tell you about my project. im putting a 95 lightning motor in my 65 f100 minuse tranny(tranny just wont fit to dam big) and havnt been able to get around making the computer work without the E4OD tranny. am i head in the right direction with this or is it all wrong.
You'd need to modify the harness a little, but a mustang ECU and harness would work since you're using a non-electronic transmission.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
A stock GEN 1 Lightning engine harness is wired for speed density. It is possible to re-pin the harness to change the injector firing order from batch fire to sequential and then add the wires for an air meter. You'll need to lengthen the wires for the ACT sensor, somewhere near the air filter would be ideal.
Another option would be a conversion harness. I use an E4OD MAF conversion on my GEN 1 Lightning and it works works fine. You can also purchase a conversion harness for a non electronic transmission as well and I believe it utilizes an ECU from the A9L family.
__________________
Matt C.
thats correct, ive been researching the hell out of this. blurry94 have you looked at the fordfuelinjection web site. i think i may use there harnness(non mustange one).
That's the other option I'm refering to; the MAF conversion from FFI's website. It may cost a little more up front, but it is supposed to be a plug-n-play type system.
__________________
Matt C.
