cheap beat-around
cheap beat-around
well, i need some advice. i am gonna buy a guys 1992 4 cyl ranger 5 speed to beat-around in. 147,000 miles, little rusty, no start. needs fuel pump, maybe. he drove it home one day, and it wouldnt start the next day. since 1999 its had injectors, fuel pump, o2 sensor, mass airflow sensor, plugs, and plug wires, and clutch. it had all the other stuff cause it had a bad computer that was reading all kinds of diff codes, then they fixed the computer, and no more problems. but he brought it home one day 6 months ago, let it set over night and no start. he says he cant hear the fuel pump engage, but he could before so hes sure its the pump. beds pretty rusty, and a lil rust around the bottom rear corners of the cab. he said he'd take $275 for it cash. good deal?
That would be a good beater if it's only the fuel pump. Remove the gas cap, put your
ear near the opening have someone flip the key to on, not start..
You should be able to hear it cycle for about 3-5 seconds.
You might be able to get the FP to go one more time
Have someone turn on the key while you smack the bottom of the tank.
I use a hammer and a 2x4 laid flat. Listen for it to cycle.
I used to just replace the female part of the harness with a new one if you can still get them they came as a repair kit from ford it had the female part of the harness that you just soldered in and a new relay.
Like I said before though I know nothing about the rangers but if they are similar to the full size trucks it may be worth a look you should hear the relay click when you turn the key .
x2...I drove for almost 2 months in my VW GTI with a 2lb dead blow hammer in it before I could a new fuel pump....had to smack the tank before every start....this was 15yrs ago
weak spark/no spark, if i remember right the fuel pump will only come on for a second as well and then shut off cause it wont think the engin in running, i could be wrong but i seem to remember something along thoughs lines. they can also be intermitin were everything works fine and then they decided to take a **** then everything is fine again. in my case i removed the distributor and found quite a bit of shaft play and opted to replace the entire distributor/tfi modual.
X2 on checking the fuel pump relay harness. The late 80's-early 90's full sized Fords had lots of problems with the connector corroding causing symptoms of a bad fuel pump. I don't know what Rangers used for a relay setup though. I know in 92 the full size went to a power distribution box and have never seemed to have troubles in that area since.
